Old 09-12-2016, 03:49 PM
Default As long as I'm doing that...
I have a couple of the cruddy black plastic vents in the plane and with winter coming, I considered buying a couple of the nice SteinAir versions and ducting them right into a spot on the corners of the instrument panel.
But then I ran into a case of the "As Long As I'm Doing Thats"
It goes something like this.
As long as I'm going to work on the panel, I might as well put the ADS-B solution in.
As long as I'm doing that, I might as well make the plane IFR capable and put in a nice GPS.
As long as I'm putting in a nice GPS, I might as well pull the D-100 out and put in the new Dynon SkyView.
As long as I'm putting in the new Dynon SkyView, I might as well pull the single axis TruTrak autopilot and go with the Dynon A/P.
As long as I'm going to have to rewire that, I might as well pull the orphaned VP-50 even though it's working perfectly because if it ever goes toes up, I'm in trouble.
Then I got to thinking, "you know... the panel works just fine as it is and you don't have the money, really, for any of this."
So I'm shoving a couple of rags in the vent.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 09-12-2016, 03:58 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
I am told that winters are long in Minnesota. I'm betting you cave in and do the vents before spring thaw.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
Old 09-12-2016, 04:12 PM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Wish I had had his will-power
Way too much "new panel" stuff in my -6A, and, I still have dreams of more!!
Ron
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 09-12-2016, 04:16 PM
DaleB's Avatar
DaleB DaleB is offline
And you have just identified exactly why the panel in my -12 remains as it was the day I bought it. Every time I decide to do something small(ish) scope creep sets in and I end up deciding to just fly the thing.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 09-12-2016, 05:14 PM
Bob,
As you know I fly all year around and this past winter I tried this solution.
Old 09-12-2016, 07:59 PM
Tbone's Avatar
Tbone Tbone is offline
Bob, please check your PM's
___________
Terry
RV7
XP IO360
Old 09-15-2016, 07:59 PM
AlexPeterson's Avatar
Default Here's what I did to seal the black plastic vents:
I added rubber sheet seals to the "throttle" part. I put aluminum backers on them. These seal very well, no problems with cold air in the winter. I like the large vents, can't imagine only having the smaller ones.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Last edited by AlexPeterson : 09-16-2016 at 12:10 PM. Reason: Trying to muscle google images in...they really are making it hard...
Old 09-16-2016, 09:50 AM
Snowflake's Avatar
Alex, your photos don't show up.
Rob Prior
Old 09-16-2016, 10:00 AM
gasman gasman is offline
To seal your plastic vents for the winter..... Take a business card and cut it in half. Open the vent and slide 1/2 in each side of the flap. Close the vent.
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
Old 09-16-2016, 11:50 AM
Default good bye google picture posting...
Rob, thanks.
It seems to be impossible to post google pictures any more. For years I did on these forums, but they are migrating people away from the old site to the new, and I can't seem to find a method on the new site that works. I also can't seem to get to the old site. I suspect they are shutting people out gradually from it.
UPDATE: I think it may be fixed, if others concur that they can now see the photos, I may have a theory...
Alex Peterson
KADC, Wadena, MN
