Old 09-11-2016, 07:18 AM
TJCF16's Avatar
TJCF16 TJCF16 is offline
Default Wheels and Breaks
I am replacing the tires and break pads on My RV9A. Does any one know the part # of the wheel assy and the break caliper? I need them to find the torque values for the wheel halves and the caliper back plate tie bolts. The torque value for the wheels should be on the sticker on the inside of rims: However the data is worn off. The construction manual says to follow the break MFG torque specs???
Old 09-11-2016, 07:33 AM
bhester's Avatar
bhester bhester is offline
Thumbs up Torques
I don't have the part numbers in front of me but the wheel half nuts are 90 in lbs and the brake pad braket bolts are 75-80 in lbs
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 09-11-2016, 07:49 AM
TJCF16's Avatar
That helps. I did find the torque on the nose wheel halves in the Vans construction manual and they get torqued to 50 - 70 inch lbs. I still would like to know the actual part numbers. thx
Old 09-11-2016, 08:07 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Cleveland Or Matco?
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 09-11-2016, 11:14 AM
TJCF16's Avatar
Not sure! Built in 2006. can't see any markings. The only thing that I know is the brake disc is Parker/Cleveland because it is marked.
