Old 09-09-2016, 08:57 AM
keen9a's Avatar
keen9a keen9a is offline
Nothing . . . put all of your tools in your vehicle so they are always with you!
Depends on how far the build is complete. I just took my whole tool chest, and bought a mobile toolbox that I really do keep in the car. The tools in the car are the ones that I might need at home.
I did take both my band saw and drill press. Can't remember using my drill press since I moved, but the band saw I have.
When I moved I still needed to install the tail, wings, and front top skin along with the 10,000 other little things you find that aren't done.
Ben Keen
RV-9 Flying 8/21/2016
http://www.pbase.com/benkeen/rv9
Old 09-09-2016, 09:26 AM
Bret,
Everyone has their opinion on when to move to the hangar. I moved earlier than I probably should have but I was stagnant and needed a motivation to keep pounding away. I only have a 15 minute drive so it isn't a big deal, but it motivated me to see things being put together. I don't get to go out late in the evening to work for a few minutes, but when I am in the hangar, I am more focused and more productive.
Have fun with the assembly and finishing your plane!
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
Old 09-09-2016, 09:36 AM
wirejock's Avatar
wirejock wirejock is offline
Default Moving
Bret
Don't forget the airplane!
Seriously, check power. Mine is anemic. Only one duplex 110 so I may end up with a gen set if serious power is needed (fingers crossed).
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 09-09-2016, 10:05 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
I just did this, so it's fresh in my mind. Basically, I took everything except my drill press. I took the bandsaw with me and am glad I did because I've used it for more than airplane construction tasks. I left my big compressor in the workshop at home and have a little pancake style compressor at the airport, but haven't needed it yet. I'm still taking bits and pieces to the airport, but I haven't had a situation yet where I was dead in the water without something.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 09-09-2016, 10:59 AM
krw5927 krw5927 is offline
Empty Gatorade bottle.
Kurt W.
RV9A
FLYING!!!
Old 09-09-2016, 11:20 AM
rzbill's Avatar
rzbill rzbill is offline
In my case, power fabrication tools were not required at the hangar. However, nearly every other hand tool that was used during construction moved to the hangar. An electric hand drill and a heat shrink gun are about the only hand power tools I have at the hangar.
You will need a small compressor for misc final tasks and continuing maintenance. Our hangars are limited on power so the compressor had to be pretty wimpy.
It was certainly a nuisance during the period of learning what to keep at home vs hangar. Still is sometimes.
***EDIT*** While it did take 4 years, I recently picked up a used cube fridge. Very handy on those hot days.
Bill Pendergrass
ME/AE '82
Old 09-09-2016, 11:33 AM
jdiehl jdiehl is offline
Default What I take to hangar
I took just about everything including compressor. Nothing worse than not having the wrench, etc., that's back at the house. Current is weak at hangar and compressor will only 'power up' when empty! Other than that, it's a great get-away. Refrigerator is also a big plus. In winter I plug in my Walmart engine preheater for a few hours before flight.
Couldn't be happier.
Jim Diehl 7A
Old 09-09-2016, 11:39 AM
ka6dan ka6dan is offline
All your hand tools, assuming your moving with a mostly complete airplane. Then go to the Lowes, Sears, or the whatever airplane supply store and buy a complete set of non airplane specific tools for the home workshop. If you don't the tool you need at home will surly be at the hanger and the tool you need at the hanger will have somehow made its way home. If the home shop is air-conditioned you'll be taking somethings to work on home and there's always a project or two requiring hand tools at home.
Ka6dan
RV9A
Phase I @ X35 is complete
Paid My 2020 dues. 😃
Old 09-09-2016, 12:37 PM
bret's Avatar
bret bret is offline
Ok, just did a HF run, pancake compressor for tires and rivet gun.....for wing bolts if the brass hammer don't work. another set of hand tools.....set one at work, set two at home, mod set three for hanger. o ya the airplane...been wrapping parts for days now. bought some more moving blankets. lights cords......man, truck and trailer are going to be full. working on trailer mods for the plane, I think it will stay on....blocks and bolts and blocks and screws and blocks and straps and blocks.... and a good one on a chair, are airport managers weird on non explosion proof lights. like a florescent...or ten?
Old 09-09-2016, 01:04 PM
snopercod's Avatar
Originally Posted by ka6dan View Post
...buy a complete set of non airplane specific tools for the home workshop. If you don't the tool you need at home will surly be at the hanger and the tool you need at the hanger will have somehow made its way home.
That's exactly right! (I learned the hard way.)
(2020 dues paid)
