Originally Posted by N42AH
So my first question is when it says unused on the spread sheet would that mean it is unavailable for usage or has not been turned on/configured for usage?
Those pins that say "unused" on the spreadsheet would be better named "unavailable".
Second question, as we scrolled thru the device configuration there were several devices listed but not were configured. Some were on the default list and some were not. Is it OK to just delete the devices that aren't on the default list to clean things up?
Sure
Third question is their a method or madness in selecting which connector to assign a device too? For the landing light above we just choose J6 because it has an empty space. Was that correct or what?
No real method - just be sure it supports the amperage required for the device.
FYI, if needed, documentation can still be downloaded here:
http://verticalpower.com/discontinued/
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
