Here are the Emails to and from Germany. Suggest any MT governor owners make a copy.
Hi Bruce ,
Thank you very much for your message and information.
You governor is affected from SB31. So please send the governor for modification to MTUSA with the following address :
· MT-Propeller USA, Inc. *
· 1180 Airport Terminal Drive
· DeLand, Florida 32724
· Attn.: Mr. Peter Marshall
· Phone: (386) 736-7762
· Fax: (386) 736-7696
· E-mail:
peter.marshall@mt-propellerusa.com
www.mt-propellerusa.com
No we do not have the same S/N for different governors . It should be P-860-3 and not P-884-3 , we will correct it during the next revision.
Thank you
Best Regards
Andreas Seperant
Engineering / Tech Support
MT-Propeller Entwicklung GmbH
Airport Straubing-Wallmuehle
D-94348 Atting - GERMANY
phone: +49( 0 )9429-9409-44
fax: +49( 0 )9429 - 8432
www.mt-propeller.com
Von: Bruce Patton [mailto:bpattonsoa@yahoo.com]
Gesendet: Dienstag, 6. September 2016 03:45
An: Andreas Seperant
Betreff: SB31
Question
My governor is a P-860-3 SN 13G256G 4/13. It is not on the list, or is it?
The list has Serial Number 13G256G but is listed as an P-884-3. Do you have the same Serial Numbers for different governors?
Thank You
Bruce Patton
