Old 09-05-2016, 10:00 PM
rv6builder's Avatar
rv6builder rv6builder is offline
Default Offset rivet set/ Crooked tails
Folks- I'm sure I'm not the only one who has been driven crazy by offset rivet sets. I'm riveting the forward top structure on my -6 and for some reason a lot of my shop heads have mushed over crooked, to the point that the edge of the hole is still visible around part of the rivet tail. Checked and double checked we are holding the gun straight, bucking bar is straight, rivets are the right length (even tried a few slightly shorter). Any ideas from the experts out there??
Alex
Alex Doughty
Canadian ATPL
Flying!!
Old 09-06-2016, 08:37 AM
JonJay's Avatar
JonJay JonJay is offline
Offset rivet sets are inherently very difficult to use. Make sure your work is extremely well supported. If your not making smiley's on the factory head, there is something else wrong. Too little air pressure at the gun, bucking bar not heavy enough, etc.... would be things to look at.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 09-06-2016, 08:43 AM
StuBob StuBob is offline
Is this what you're saying: If the problem was that the offset set was hitting the heads at an angle, he'd be getting smilies. If he's not getting smilies, the problem isn't directly related to the offset rivet set.
Excellent point.
Stu F.
RV8
Old 09-06-2016, 08:58 AM
nilberg nilberg is offline
Two other contributing factors are:
- Rivet not 100% straight in the hole due to slight misalignment of the layers. So even if the bucking bar is normal to the surface, there is a misalignment between the force from the rivet gun and the bucking bar.
- Rivet a little too long.
Most of my crooked rivets are a combination of the two above.
Old 09-06-2016, 09:03 AM
rv6builder's Avatar
Thanks for the info guys- Ill give it another try after work today. Cheers!
Alex
Alex Doughty
Canadian ATPL
Flying!!
Old 09-06-2016, 12:28 PM
Tom Martin Tom Martin is offline
another common problem is the offset rivet set trying to turn during riveting. Use electrical tape and securely tape the set to the gun so that the set can not swivel.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 09-06-2016, 12:31 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Or hold it with your fingers if another person is on the bucking bar.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-06-2016, 01:03 PM
rvbuilder2002's Avatar
All good discussion regarding an offset rivet set, but as mentioned, if there is not visible damage or influence to the manufactured head, it is not likely caused by what rivet set you are using.
Rivet length, enlarged holes or bucking bar technique (or a combination) are more likely causes.
Scott McDaniels
Hubbard, Oregon
Old 09-06-2016, 05:36 PM
rv7charlie rv7charlie is offline
Alex,
What everybody is dancing around, is that an 'offset rivet set' is a tool with at least one; usually two, bends in it, that is inserted in the end of your rivet gun. The posts describing 2 people holding one rivet gun are talking about that. I'm pretty sure they were created by guys looking for a good deal on a slightly messed up pre-owned kit.
A shop head that sets off-center or bent ('clinched') is likely what you're asking about. As others mentioned, bucking bar alignment is important, but keeping the bar from 'wiping' across the shop head is also important. If it moves sideways during riveting, it can move the shop head with it.
Charlie
Old 09-06-2016, 05:59 PM
bruceh's Avatar
bruceh bruceh is offline
The problem with the longer rivet sets is that they have more mass than shorter rivet sets. I had to really bump up the air pressure whenever I used an offset rivet set. Try using 75 psi on some scraps and see if it helps get the rivet bucked quickly. If you have to pound away at it with lower pressure, the rivet will work-harden and then the tails will tip over instead of smoosh smoothly.
Bruce Hill
2020 VAF donator
