Hi Ron
On your 796 , press on the little arrow ( Pointing left )The ''Back'' key, in the bottom left corner of your 796..
--Click on '' Tools''
--Click on ',Track Log''
--Click on''the 3 little Bar''Menu Key'' ( To the right of the Back Key''the little arrow at the bottom of your 796)
-- Click on '' Clear Active track'' in the menu shown
-- Click on ''Set Up'' in the Menu
__ In the menu just below the Moving map shown, there are 2 green arrow with menus attached, click on the ''Line ''
--There you will see different menu with the track log at the top, just select the Track Log menu to ''Hide'' then you should be set..
--- Just do the process in reverse if you want your Track Log back..
Have fun during your phase one..
Cheers
Bruno
rv4@videotron.ca
