Old 09-02-2016, 02:46 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Default First Engine Start
If you're bored and want to watch yet another first engine start video, click here: https://youtu.be/VnitFWTo90Y
No leaks and no fire...engine misses a little at first. Got some work to do there. All temps looked good.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 09-02-2016, 02:50 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Default Congratulations!!
Mark, congrats on one more item off the ever shrinking punch list
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-02-2016, 03:13 PM
Raymo's Avatar
Raymo Raymo is offline
A little air in the fuel lines?
Nothing boring about the first run! Or should I say, it should be boring - else expensive.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 09-02-2016, 03:28 PM
cjhammes's Avatar
cjhammes cjhammes is offline
Thumbs up
Congrats Mark! Another step closer.
Great meeting you at KOSH.
Charlie
Charlie Hammes
RV-8, N525RV Flying
RV-8, N208CH in process
Old 09-02-2016, 06:56 PM
Charlie
Great meeting you as well. Next year I'll be flying there in the -8
www.marksrv8.com
Old 09-02-2016, 07:15 PM
That's how we do it congratulations Mark! Look for those leaks you don't see them but they are there.
Old 09-03-2016, 11:17 AM
I don't doubt it and I'll keep looking for them
www.marksrv8.com
Old 09-03-2016, 01:13 PM
Captain_John's Avatar
Nice job Mark!
You will be flying soon!
CJ
The experiment works!
Old 09-04-2016, 06:36 AM
Congrats Mark----Youre on the down hill run now.
Tom
Ridgeland, SC
Old 09-04-2016, 08:23 AM
Mark,
I know you have AFP injection, can't tell if you have the purge valve.
On start, I get a stumble after light off unless initial prime is perfect. I am still fussing with it after 137 hours. Latest prime is 6-7 seconds and that works well most of the time. There are so many variables, like throttle position, OAT, etc.
I believe the issue is AFP controller finding its brain re air/fuel mixture and flow. Once it gets it's act together engine runs smooth until shut down.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
