08-29-2016, 07:33 AM
Stupid basic rivet sizing question
For two sheets of dimpled .032... AN426AD3-?
I just need to order a bunch and I'd like to be sure.
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
08-29-2016, 08:18 AM
The RV7 typically uses AD3-3.5 in situations like this. An AD3-3 may also work.
Michael
Danville, IN
RV-7A Canopy/Finishing
N317PU Reserved
2020 Dues paid (February 2020)
08-29-2016, 08:37 AM
You want to be sure.... order a 1/4# of each 3-3.5, -4, -5, etc. You won't regret it!
Jerry Esquenazi
RV-8 N84JE
08-29-2016, 08:41 AM
Let's do the math, just in case I screw up, others can double check.
AN3 rivet diameter = .09375
1.5x diam. = .140
.032 + .032 + (.09375 x 1.5) = .204
AN3-3 = .1875 - .064 = .1235
AN3-3.5 = .2187 - .064 = .1391 looks like a winner....
AN3-4 = .250 - .064 = .186
I would be tempted to try the -3 and see if the shop head will pass. Often dimpled holes will be slightly oversized. At 1.5d protrusion, you might find some cleating over. The -3, which is slightly less than 1.5d protrusion would be easier to set.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
08-29-2016, 09:04 AM
trays-o-rivets
My rivet tray has been through several RV builds  I've lost track of which are the one's for two sheets of .032 and I can't find them anymore. Time to resupply and sort.
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
08-29-2016, 10:55 AM
Buy a hundred dollars of rivets and save $100 in shipping for small lots later. It is like they are free!
Bill
RV-7
Lord Kelvin:
08-29-2016, 02:55 PM
Most of the sheet metal to structure on my -7A is held together with AN3-3.5 per Van's plans. I keep at least a 1/4 lb on hand.
As others have said, order a variety and have them ready when needed. You might find another builder/flyer nearby that will add to the order.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
08-29-2016, 03:19 PM
09-02-2016, 04:47 PM
Like others said, AN rivets are cheap, get a bunch of each size (if you were doing CherryMax, that might be a bad idea...says the guy who just spent ~$40 on 40 cherry rivets).
I personally just use a ruler for those cases - put the rivet in the hole (without squeezing it), and measure how much protrudes out on the other side.
Once you've done this a few times you'll also be able to tell just by looking (but I'm not going to recommend not checking with a proper measurement device  ).
Rodrigo Damazio Bovendorp
San Jose, CA
RV-10 builder #41623
Build log at http://www.airplane.build/
VAF dues paid
