Go Back   VAF Forums > Model Specific > RV-14
Old 08-29-2016, 06:12 AM
Reflex Reflex is offline
Default Rivet question before I get to the point of no return....
If there's a prize for the most hours spent on a vertical stabilizer, I may qualify. Things have gone well, it just my lack of experience that has slowed me down. I've got a pretty good idea of what good work is, but I don't know what's acceptable so I probably spend too much time trying to be perfect. Because of this I've got a lot of time in this very simple piece. I was down to the last rivet on the top end of the vertical stab when I ran into a problem. I can't get the rivet to set flush. Below is how events unfolded.
  • Dimpled using rivet puller dimple dies
  • Used proper rivet but but head was high on one side
  • Removed rivet successfully
  • Retried to set rivet. High on same side
  • Tried to set rivet a 3rd time. Very high on same side
  • Decided hole enlarged
  • Used #30 reamer for oops rivet
  • Set 1/8" Oops rivet. Did not set well. Very poor set
  • Removed oops rivet successfully
  • Decided to post here before hole becomes unusable
I'm using a Cleaveland Main Squeeze type squeezer and the yoke I'm using appears to fit well into the small space at the shop head end of the rivet. I'm wondering if my dimple is not formed properly since I used the puller type dies due to the space restriction.
Any help is appreciated. Pictures are below:
Fred
Dues Paid for 2022
RV-14
Emp Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse Complete
Working on Finishing Kit
Working on Avionics
Old 08-29-2016, 07:24 AM
BillL BillL is online now
I am building a 7, but in this case a suggestion, spin the deburring tool in there 3-4 times lightly to true up the countersink and check the rivet fit, if it is perfect then good to go, unless - - - unless it always fit and it setting it has caused the lifting head. No guarantee. Good luck. Oh - I am assuming you have a no-hole yoke that allows good axial alignment of the main squeeze.
Bill
RV-7
Old 08-29-2016, 02:23 PM
Mudfly Mudfly is offline
Default My Opinion
I can relate to your strive for perfection. I'm on step six of the recovery plan myself I've re-built parts (1 VS, 1 elevator, 1 trim tab) over mistakes that, looking back, I should have just left alone and "built on". In most (all) cases, the parts that I have re-built, did not turn out perfect either.
You have done the right thing by stopping, taking a breath and asking for help. I have made rash decisions to "fix" something and next thing you know, the Van's truck is pulling in the driveway with new parts.
Your workmanship looks great and the attention to detail is obvious (e.g. nice trimming of that nose rib). You have one rivet that you are not happy with. I know the feeling. I personally don't think it will be a structural integrity issue later on. I think at this point it is a cosmetic issue. I believe you just need to get a good, mostly flush, rivet head on the skin side. It is tight quarters in there so your options are limited. Could you try and "reform" the dimple, rib included" using your pop rivet dimple die? That may help get things lined back up while re-forming the dimple. Then, put on your 3x magnifying glasses, push down on the rivet head as best you can, and very slowly squeeze the rivet. It may lean a bit, and may not be perfect, but should be good enough. It may take you a few days to come to peace with it, but give it a try. The other option (I personally wouldn't do now that I'm on stage 6 of recovery), would be to drill the rivets for that tip rib and replace the whole thing. Chances are very high that you will end up with something that you will like less than what you have now. Then, the Van's truck may need to be called to deliver the "big box" to your doorstep!
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2021 VAF Donation
Old 08-29-2016, 02:28 PM
IMHO the pull dimple dies do not work well unless you pull hard enough to break the nail (or nearly so).
Old 08-29-2016, 02:50 PM
oceanbird oceanbird is offline
I have found that pulled dimple dies very often make a dimple that is not
centered on the hole. Sometimes is higher on one side. I think that´s what
"started" your problem.
I have done some tests with different brands of nails, and I got better results, but, a pull dimpler dimple is never as good as one made with a squezeer.
Those vise grip pliers that have dimple dies welded on the tip work better, when you can use them.
Old 08-29-2016, 03:00 PM
Gentlemen,
Thank you very much for your replies.
BillL, I know you've been instrumental in helping a large number of people here. I value your opinion. I'm not sure I've got the skill yet to use a deburring tool on something this thin.
Bob, I agree about breaking the nail. Good advice. In fact, when the first nail broke, I didn't feel like the dimple was deep enough so I put a stronger nail in and broke it as well. The dimple was almost deep enough, so I used the same type of nail one more time and I thought I had the dimple right. This method worked very well on the other side, I guess I need to learn to work upside down!!
Shawn, I was hoping to get a response from you. I've visited your blog countless times. You're work is exemplary and I look at your site to see how you've done something almost daily. In fact if you saw my shop, I think you'd feel right at home!
At this point I agree that it is mostly cosmetic. My course of action here is just to find something that is acceptable. I'm not looking for perfection, that ship has sailed. If I'd have stopped with the first rivet and use a very small file, I'd be in great shape. I'm going to head out to the shop this evening and make my usual scrap pieces and test out a few ideas to see if I can get a rivet somewhat flush.
The first oops rivet was probably the worst set I've ever done. I'm a bit hesitant to try again until I test some other ideas on the bench.
Thanks again guys, if it wasn't for this forum, the number of completed/flying RV's would be significantly less. I hope that one of these days I have the skills to contribute and help somebody as so many here have done.
Fred
Dues Paid for 2022
RV-14
Fuse Complete
Working on Avionics
Old 08-29-2016, 03:22 PM
longranger's Avatar
Originally Posted by Reflex View Post
... I'm not sure I've got the skill yet to use a deburring tool on something this thin.
Fred
It takes very little skill to give the hole 3-4 turns with this deburring tool. You MIGHT get 0.001" of depth per turn.
Miles (VAF# 1238, Paid up as of 12/20)
RV-7 TU 904KM (reserved)
Construction Log
Empennage Album, Wings Album, Fuselage Album
Old 08-29-2016, 03:31 PM
JonJay's Avatar
JonJay JonJay is offline
I think everyone has you going in the right direction. Just a couple ideas for future reference. You should be able to get a Tatco or other manual squeezer in there to form a better dimple. If you don't have one, time for a new tool always time for new tools.
There are a few places that countersinking vs dimpling make sense and this is might be one of those. That is an .032 skin right? Dimpling a curved surface can produce inconsistent results, but so can countersinking if you have not developed those skills.
Lastly, you are being really picky, which is good. You could file the protruding rivet head carefully with a jewelers file and move on. Your finger can pick up an edge of less than .001 of an inch by feel. You could do nothing and nobody would probably ever notice.
It is nice to see so many folks on here paying such great attention to the quality of their work.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 08-29-2016, 03:54 PM
sbal0906's Avatar
sbal0906 sbal0906 is offline
I feel your pain. I'm running into a similar problem dimpling the forward tip of the top rudder rib of my -9A. The pop rivet dimpler didn't give me a dimple that I liked. I tried bending the flange back a little but still couldn't get a good dimple. In the process, I may have flexed the flange too many times so I ordered another rib. I epoxied the female dimple die of the pop rivet tool to a 1/8 inch strip of steel and I'll see if that works. I can try either striking from the other side with a male die and hammer or hammer a rivet from the other side using rivet gun to get a dimple.
Cheers.
Shamit Bal
RV-9A
Working on wing - fuel tanks.
Winnipeg, Manitoba, Canada
Old 08-29-2016, 04:03 PM
rv9builder rv9builder is offline
Default Two other possibilities
Cleaveland sells a couple of tools that might work. I used this vise grip dimpler in a few spots on my 9A project. It works pretty good if there's room to use it.
http://www.cleavelandtool.com/3_32-V.../#.V8ShjnCSIvY
This tight-fit dimpling fixture might also work. I've never used it, but it looks like it can get into tighter places than the vise grip dimpler. Here's a video that shows how to use it.
http://www.cleavelandtool.com/Tight-.../#.V8Sge3CSIvY
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2021
