Old 01-08-2007, 08:22 AM
prkaye prkaye is offline
Default Duckworks landing lights
i'm going to go with the Duckworks leading edge landing lights, supplied through Vans. Two questions:
1) I'm going to go with either the rectangular or the round ones (not the super-expensive HID ones). The "round" ones cost are $115, instead of $75 for the rectangulars. Is it worth the extra money? What's the main advantage of the rounds.
2) I want to keep weight down, so I'm wondering if one landing light would be sufficient? Of course, it would be asymmetric, having one light on one wing... but maybe this isn't a big deal? Has anybody installed one of these, and found it to be enough, or not enough? If I go with one, which wing should it be on?
Thanks!
Phil
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-08-2007, 09:00 AM
dan's Avatar
dan dan is offline
What % of your flying to date has been at night? Gotta ask yourself if you'll honestly do a lot of night flying.
But hone the goal as well. In my case the goal is daytime recognition more than anything else, and I like having two in order to wig-wag.
Dan Checkoway RV-7
Old 01-08-2007, 09:09 AM
I intend to do a lot of cross-country flying, which will inevitably include a lot of night flying.
Wig-wag?
Phil
RV9A (SB)
Ottawa, Canada
Old 01-08-2007, 10:54 AM
randylervold's Avatar
randylervold randylervold is offline
moderator
Phil,
I had the regular rectangular Duckworks lights in my RV-8, then when they introduced the round version thought I'd try them. I installed the round version in one with and lived with it for a while. In the end I didn't like the light dispersion pattern as well as the the rectangulars... it was more tightly focused, to narrow for me. Also, the rounds are of course heavier.
Personally, I'd put two lights because there is little weight penalty and you get the benefit of better lighting and the ability to install wig-wags which I'd highly recommend.
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse in box
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
Old 01-08-2007, 11:07 AM
Originally Posted by randylervold
Phil,
Cool, probably two rectangulars then. Should I cut the hole in the skin prior to riveting the skin to the skeleton, or after? What are wig wags?
Phil
RV9A (SB)
Ottawa, Canada
Old 01-08-2007, 12:11 PM
kentb's Avatar
kentb kentb is offline
Cut the hole after.
Wig wag lights switch on and off like turn signals. They do this opposite each other. This really makes your plane stand out when view from the front. The wig wag is just a small box and you will want a switch to turn it on and off. Weighs only a couple of ounces.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 01-08-2007, 12:37 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Wigwag
Just think back to the last time you looked in the rear view mirror, and saw a cop commin' up on you in a big hurry---------headlights flashing side to side.
Real attention getter aint it??
Mike
Old 01-08-2007, 02:04 PM
rv8bldr's Avatar
rv8bldr rv8bldr is offline
Hi Phil
I got the wig-wag switch from Perihelion Designs. It was dead simple to install (which is good because I'm a S/W guy, not a H/W guy ) and really works well.
Here is the link:
http://www.periheliondesign.com/wigwagdmnl.htm
Cheers
Mark
RV-8 C-GURV (Flying since Nov 2004) - Sold
Scratch building 4pl Bearhawk
Flying a '79 Maule M5-235C
President EAA Chapter 245
Old 01-09-2007, 07:10 AM
PaulR PaulR is offline
Default Cutting Hole
Phil,
I just finished doing both leading edges. I cut the holes while everything was clecoed together prior to riveting. While the directions from Duckworks say it can be done in a finished leading edge, I wouldn't want to do it that way. I painted the inside of the leading edge white, thinking that it would look better than the bare alclad, but after doing it I'm not so sure I'd do it again.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
Old 01-09-2007, 07:17 AM
IowaRV9Dreamer's Avatar
IowaRV9Dreamer IowaRV9Dreamer is offline
Default went round
I just bought the round halogen DW lights. I chose them over rectangular because the upgrade path to HID is easier. The kit seems very high quality, and the directions are excellent. I will be putting them in during construction; starting with the nutplates in the ribs really soon!
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
