Go Back   VAF Forums > Model Specific > RV-4
Old 08-23-2016, 04:30 PM
keijidosha keijidosha is offline
Default Cowl Piano Hinge starting to Zipper
Pulled the cowl for an oil change and found the first three tabs on the upper front side of the upper/lower cowl piano hinge broken off. I heard them clatter into the bottom cowl as I pulled the wire pin out the front.
I'm the second owner. Can the hinge be replaced? If so, can the damaged segment be replaced or does the whole hinge have to go?
Airframe has 130 hours TT. Also have a call out to get the engine/prop dynamically balanced (better late than never I guess).
Matt
Simi Valley, CA
RV-4 O-320 F/P
Old 08-23-2016, 04:49 PM
Beancounter Beancounter is offline
Default piano hinge
Matt
you can probably cut off just the damaged section and replace, however alignment will be important. Try to keep it straight by inserting the pin and the other half of the piano hinge when you drill the rivet holes. Drill one hole, cleco it, repeat. You may want to put a doubler over the joint to reduce flexing.
C-GVMK
RV9a Slow(ly) built
Flying as of July 2012
Old 08-23-2016, 05:49 PM
Steve Barnes Steve Barnes is offline
Default Not that big a problem!
Both my RV's have done this. It just screws up the paint job a little. Bean counter has it right. Be sure to use a mini rat tail file and file the inside square corners of the new segment of hinge (stress risers).
Steve
Old 08-23-2016, 06:29 PM
Might be worth getting the more expensive extruded piano hinge for this. Van's sells it and so does Aircraft Spruce and probably other vendors. You can get it in the same size.
Dave
Old 08-23-2016, 07:16 PM
BillSchlatterer BillSchlatterer is offline
Default Pin Size ??
Assuming you are using the undersize hinge pins. The larger ones that come with the hinge put a lot of stress on the eyelets in any kind of curve ....
Bill
Bill S
Got the Grin :-)
7a Ark KORK
BillSchlatterer@sbcglobal.net
Dues Paid 2/24/2020
Old 08-23-2016, 07:45 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Dave
+1
I put an extruded hinge on the left bottom cowl for the same reason. Problem solved.
Carl
Old 08-23-2016, 10:58 PM
Dave
Originally Posted by Carl Froehlich View Post
+1
Carl
Good tip. Ordering the extruded hinge.
Matt
Simi Valley, CA
RV-4 O-320 F/P
Old 08-24-2016, 06:17 PM
Default Hard or Soft Rivet?
To attach the hinge, plans call out AN426AD3-4 (Hard) Rivets. Instructions have a note saying ?when setting solid rivets in fiberglass, use soft (AN426A3-4?) rivets or do not fully set normal rivets." Any advice on preference?
Matt
Simi Valley, CA
RV-4 O-320 F/P
Old 08-24-2016, 07:03 PM
Default rivets
I would use the regular rivets and under squeeze them so as not to stress the glass.
Old 08-24-2016, 08:32 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
Also drill 1/4 inch holes in between the rivet holes and embed the hinge material in epoxy when riveting. The epoxy will flow up through the holes and add some strength.
I could hear the glass "creaking" hand squeezing rivets in the old white cowls, but didn't get the same effect in the new, much harder epoxy Pepto-Bismol colored cowl.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
