Old 08-22-2016, 09:06 AM
Ricemv Ricemv is offline
Default Desser Elite Tire retread failure
Two weeks ago I had a Desser Elite retread on my RV-8 start to come apart (tread separation) on landing. The tire has been on the plane about two years and still has about 75% tread remaining. This caused considerable damage to my wheel pant but fortunately did not completly come apart during the landing.
Desser has been notified of this problem and sent pictures showing the delamination but has failed to respond. Tire problems can be difficult to see with wheel pants but i would advise anyone flying with Desser retreads to inspect the tires for problems - takes less time than rebuilding and painting the wheelpants
Old 08-22-2016, 09:58 AM
Chkaharyer99 Chkaharyer99 is offline
Glad to hear you are ok. Sorry to hear about the wheel pant.
I had a problem with a brand new Desser Elite retread on my RV-8 as well.
After mounting a new set and before putting on the wheel pants a friend walked in and looked my tires over. He noticed a large bulge/bubble protruding from the side wall. I left it inflated overnight which resulted in a sidewall blowout.
Desser made me whole, sending a new tire and tube at no cost in short order. Good customer service.
Charlie
RV-8
Old 08-22-2016, 10:11 AM
bkthomps bkthomps is offline
i can't think of any amount of savings in the tire budget that would allow me to forfeit the peace of mind associated with having fresh goodyears under me on each landing and takeoff
Old 08-22-2016, 10:21 AM
krw5927 krw5927 is offline
How are they fresh every time? Aren't they used tires after the first takeoff?
No problems with my Desser Monster re-treads.
Kurt W.
RV9A
FLYING!!!
Old 08-22-2016, 10:24 AM
ssmdive's Avatar
ssmdive ssmdive is offline
Big difference between worn new tires and re-treads. Seeing all the thrown re-treads by trucks on the roads, I just buy new tires.
I can't imagine a cost savings so high that re-treads are worth it. <--- My personal opinion, yours may vary.
1996 Challenger II CWS - Sold 113 hours
1974 Citabria 7ECA - Sold 211 hours
RV6 Partnership - Sold
1986 Pitts S1S - Flying
Old 08-22-2016, 10:57 AM
n816kc n816kc is offline
Default Elite retreads
On my second set of Elite retreads. No issues in 400 hours/500+ landings.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2019 =VAF= donor
Old 08-22-2016, 11:22 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
You might want to look more closely at those "road alligators" you claim are retreads. As an old trucker, I never lost a retread! Most of what you see are actually parts of non-retreads that have failed, not retreads. It has been years since I have seen a recap peeled off on the highway.
[quote=ssmdive;1105441 Seeing all the thrown re-treads by trucks on the roads, I just buy new tires. [/QUOTE]
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 08-22-2016, 11:43 AM
Sam Buchanan's Avatar
been here awhile
I've been told a huge percentage of tires on commercial airliners are retreads, many of the carcasses get retreaded more than once.
Desser retreads have been on my RV-6 for many years, never had any service issues. The retreads often have more tread depth than new tires.
Yep, the "road gators" are failed carcasses, run any tire flat long enough and it will eventually overheat and disintegrate.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 08-22-2016, 11:48 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Same with U.S. Military aircraft tires. The overwhelming majority are retreads.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 08-22-2016, 12:58 PM
Steve Barnes Steve Barnes is offline
Default 5 TIMES
Desser retreads casings up to 5 times. On a recent visit to Desser in SoCal they showed me the stamps on the new treads that start with 1 and go to 5 their max amount of retreads per casing. They carefully inspect and look for cracks in the sidewall. A couple of my older tires got rejected because of sidewall cracks.
Steve
