Go Back   VAF Forums > Main > Safety
  #21
Old 01-06-2017, 09:14 AM
skylor's Avatar
skylor skylor is offline
Originally Posted by Foxmoth View Post
Spin was IMHO very standard - at light buffet, full rudder and up elevator, the prop stopped as the aircraft autorotated, when I restarted it was at low power and recovered immediately on engine restart, following this I leaned the mixture and recovery was normal with engine at idle.
Just to clarify, you're saying that the -7 won't recover using the PARE method with the prop stopped, correct? How many turns before the recovery was attempted? Is this with a fixed pitch prop? I suspect that the difference between having some idle residual thrust and true zero thrust with the prop stopped makes just enough difference with rudder and/or elevator effectiveness, that more positive (than PARE) spin recover inputs are needed when the prop is stopped on this particular aircraft.
In my -8 with a fully developed (3 turns or more) spin to the right, using positive (opposite rudder) recovery techniques, I need the elevators farther forward than neutral to stop the spin.
Skylor
Old 01-06-2017, 06:23 PM
RV7A Flyer's Avatar
This will NOT work for all aircraft, the dHC1 Chipmunk springs to mind, recovers fine using PARE but often will NOT recover until you have FULL forward CC!
Also of interest was the spin tests on our RV7, recovery was fine to the left, first spin to the right the prop stopped (at height with full rich mixture), recovery was not possible with ANY of the methods discussed with the engine stopped, as soon as I restarted the engine recovery was almost instantaneous!
Not sure I understand...are you saying that the engine stopped *during* the spin to the right? Or you had stopped the engine prior to entering the spin, and the prop windmilled when going to the left, but not to the right?
I can't imagine why the engine would stop during a spin...so I must be reading this wrong.
Old 01-06-2017, 08:23 PM
luddite42 luddite42 is offline
I only know of two reasons - one...that you are running a wood/composite prop and your idle setting is too low for the lack of relative wind through the prop to keep the prop windmilling. During a spin, the relative wind develops a higher angle of attack as the spin develops. Been there more than once. Two...that your fuel level in the wing tanks is insufficient to cover the fuel port as the fuel is forced outward during the spin.
Old 01-07-2017, 03:34 PM
Foxmoth Foxmoth is offline
I am not saying the -7 will not recover, just that THIS -7 will not, I would be very interested if anyone else has had the prop stop on entry and the result! Recovery was initiated after 2 turns and took 12 and yes, a metal fixed pitch prop.
Engine stopped as I entered, I just closed the throttle, I think it was probably a combination of airflow, spin direction and mixture setting (at 8,500' with full rich and partially leaning meant this did not happen on subsequent spins)
Old 01-07-2017, 04:52 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Fuel migrates to the outboard side of the tank, depriving the engine of fuel. This can result in the prop stopping, especially if a low mass (wood or composite) prop is installed.
Also, I think Ron asked why prop stopped or not would make any difference in recovery. Consider the gyroscopic precession forces associated with a spinning prop - I could see how such would have an impact on recovery.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 01-07-2017, 08:40 PM
ronschreck's Avatar
ronschreck ronschreck is offline
I have recovered my RV-8 from spins with prop stopped due to fuel migrating away from pickups during extended spins. Recovery of MY airplane is same with prop stopped or with idle power. Not sure why your experience is different.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 01-07-2017, 08:57 PM
ChiefPilot's Avatar
The side-by-sides are known to have different spin characteristics than the tandems, for starters. That combined with the lack of precession forces and/or the unique characteristics of a given airframe could very well present different spin characteristics.
Old 01-07-2017, 10:17 PM
RV7A Flyer's Avatar
Different, maybe...but...unrecoverable with the prop stopped? That sounds not good to me. If that's the case, then the plane should probably be placarded for no aerobatics, perhaps?
Old 01-08-2017, 12:58 AM
skylor's Avatar
I'm still trying to clarify your answer: When you say your plane won't recover with the prop stopped, was that using only the Finnegan method (neutral controls) , or did you try anti-spin control inputs as well (PARE)?
Skylor
Old 01-08-2017, 06:23 AM
ronschreck's Avatar
+1. If it were my airplane I would ground it. Something definitely wrong with it.
Ron Schreck
IAC National Judge
VAF 2021 Donor
