Increase the Alt Fld breaker size and wire, if necessary. I have a 50 amp alternator and followed the advice here that 5 amps is more than adequate for a fld breaker. One day, early in my Phase 1, I ran the battery down a bit starting the engine. When I do this, I see 45+ amps of cuurent. during that flight, i noticed my voltage was low and sure enough the fld breaker tripped. I kept pushing it in and it would pop in 15 seconds. Had to do this all the way back to the airport.
I replaced the breaker with a 7.5A unit and never had a problem again, even when drawing 49 amps. It is possible that my breaker was defective, but I believe the field current requirement is higher than 5A for these bigger alternators. Remember, the greater the output of the alternator, the greater the field current requirement is. This is how the VR regulates that output.
Larry
