Old 08-15-2016, 07:09 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Ring gear choice, 122 vs 149
I have a magnaflite starter with 122 ring gear. It seems alittle weak even with 7:1 0320 and new solenoid and pc680. My goal is NO problem!! I plan to buy a light weight no pully flywheel and B&C starter. B&C says 149 tooth has slight advantage in crank torque. I have read this is a myth.
what is truth ???
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 08-15-2016, 08:24 PM
jrs14855 jrs14855 is offline
Default Gear
My 320 with 10-1 pistons cranks extremely well with 149 ring gear and sky tec starter
Old 08-15-2016, 08:35 PM
airguy's Avatar
airguy airguy is offline
What prop do you have? A heavier prop adds angular momentum and will help a starter overcome the compression stroke, while a very lightweight prop will have trouble, especially with a weak starter. I had the combination of a relatively light prop (Whirlwind RV200) with the Magnaflite starter on my IO360, and it would not handle the compression stroke worth a flip. I changed to the SkyTec 149NL and my problems were solved, though it comes with it's own set of maintenance inspection quirks (no free lunch).
Old 08-15-2016, 08:44 PM
Default Prop
Sterba prop on mine. Direct ground from battery to starter mounting bolt makes a huge difference.
Old 08-15-2016, 08:53 PM
RV6_flyer's Avatar
what is truth ???
Should be no difference.
It is possible to sometimes replace the starter ring gear with one of a different size. There has been problems doing this with some starters. Read this to learn about possible problems. http://www.skytecair.com/RingGearTech.htm
I have changed a 122 tooth ring gear to one with a 149 tooth ring gear like listed in the above link. In my case, it worked but in some cased it may not work due to clearance issue documented in the above link.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-15-2016, 09:25 PM
Default Starter
I disagree almost entirely with the skytec info. Many early Pipers with the low compression engines had the 122 tooth starter and had at best mediocre cranking capability. The same starter on a Twin Commanche with high compression engine but 149 ring gear(with matching starter gear) cranks the engine noticeably better.
