Old 08-15-2016, 10:50 AM
aturner's Avatar
aturner aturner is offline
Default Altitude and RPM
You guys with -9's are posting impressive numbers, you might have to form your own club. :-) As to the question as to what is going on with my -10, it might be a few knots faster than average, but I suspect that the most important things to note are the operational parameters.
In the post above, I am at a density altitude of 17,000 ft., and it seems that the unique airfoil of the RV-10 loves altitude. I am guessing that this has something to do with air density, Reynolds numbers, and laminar flow, but someone smarter than me can confirm this. Here is a plot showing segments of different cross-country flights, with cruise altitude plotted against fuel efficiency for each one:
These are flights at different configurations of power, RPM, fuel flow, etc., but even so, it is altitude that has the overwhelming effect on efficiency. And higher is better, at the rate of one mile per gallon for each 3000 ft.
The other operational aspect to note is the low prop RPM. I am running old fashioned Slicks at 25 deg. fixed timing, and 30-40 degrees lean of peak. As several excellent threads here have explained, the flame front needs time to do its work at high altitude and lean mixtures. Here is a plot from a test in which I did mixture sweeps at RPM's ranging from 2400 to 2000. Superimposed on the plot are isopleths for nautical miles per gallon. Test conditions were 9200 density altitude, so maximum efficiency is only about 18 nmpg.
There is a lot to be learned from this graph, but the simple point is that the maximum efficiency was at the slowest RPM tested, 2000. Here is another recent graph, showing the results of a test in which I simply reduced RPM in a stepwise manner while on a cross country flight (14,000' DA), without touching anything else.
X-axis is RPM, y-axis is true airspeed divided by fuel flow (nmpg).
So, fly high, and for those of us with magnetos, keep that prop slow.
-Andy Turner
RV-10 N784JC
Old 08-15-2016, 11:56 AM
togaflyer togaflyer is offline
Im not an engine expert, but if your running your rpms that low under a load, aren't you putting significant load on the engine.
Old 08-15-2016, 06:53 PM
tfoster100's Avatar
tfoster100 tfoster100 is offline
I can't wait to get an RV-10 or 9A. Those numbers are awesome. I'm building experience and hours in a 182.
Tim Foster
Dues paid thru 2020
Building RV-14a kit # 140381
Finish kit in process
182 Sold 😂
https://eaabuilderslog.org/?s=tfoster
Old 08-15-2016, 07:35 PM
Weasel's Avatar
Weasel Weasel is offline
Our -10 will go 177knots on 10.7 GPH at 12,000ft Density Alt which works out to little over 19 statute MPG. I can get well over 20 MPH by slowing down just a little by leaning slightly. That is the only hard data I have handy.
will try to collect some efficency numbers soon.
Weasel
RV-4 715hr Sold
RV-10 "School Bus" - +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
Old 08-15-2016, 09:14 PM
aturner's Avatar
Your data point falls right on the curves I posted above for the mixture sweeps. I routinely plan on, and see, 170 knots on 10.0 GPH at 12K, which also seems in line with your report.
-Andy Turner
RV-10 N784JC
Old 08-16-2016, 07:27 AM
bobmarkert's Avatar
bobmarkert bobmarkert is offline
Default 24.7 MPG
On the way to Oshkosh:
9,500?
-100 LOP
FF 6.6 GPH
163 KTAS
MPG 24.7
RV-8 with an Aerosport IO-375 high compression motor
Bob Markert
Littleton, CO KBJC
Reserve Grand Champion Oshkosh 2016
Renegade Opposing Solo pilot and other Dirty Odd Jobs
http://www.rmrairshows.com/
2019 dues paid
Old 08-16-2016, 09:20 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Originally Posted by rleffler View Post
Please help me understand how you were able to get 7.9g and 155kts IAS.
What ignition are you using? Did you do anything special with the timing? Do you know how far LOP you were?
Most RV-10s that I'm aware of are getting 10-11g at 155kts.
In my RV-10, anything below 11gph and the engine starts to run rough.
bob
Here are two screenshots from my last flight from Minnesota to Chicago. First one is LOP, second is ROP. The ROP settings were just quick and dirty to get a rough comparison, and were by no means tweaked for max performance.
Totally agree. In my limited time flying my -10 (around 100 hours) I've found that I don't like cruising much below 9500. Better speed and efficiency!
I have dual electronic, and I've been normally cruising between 2360 and 2400, WOT. I'll have to play around with pulling RPMs lower.
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 08-16-2016, 09:21 AM
jchang10 jchang10 is offline
It seems like the -8's are the winners in "total" performance (ie. speed combined with efficiency). I wonder what an -8 with -9 or -10 wings would be like. Anyone else curious?
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 08-16-2016, 09:27 AM
NovaBandit's Avatar
Not if the performance number you're looking at is "passenger mile per gallon"!
Ed Kranz
Old 08-16-2016, 10:43 AM
rleffler's Avatar
rleffler rleffler is offline
The missing data point for me was DA. When you take DA into consideration, I'm getting similar numbers.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
