Hello Gents
Thank you for the info.
So it is the 90 degrees stem as I thought...can't never be too sure.
I'm also leaning toward the Leakguards tubes as they seems to be as good as the Michelins for less money..
As for the tires looking at what is available from AC Spruce Canada I thinking of buying the Goodyear Flt Special 2 which looks to be very good...
One question for the ones of you who have used the Goodyears(Wide rib tread design and
large footprint), will they fit with the original wheel pants without having to enlarge the hole..??
Thanks again
Bruno
rv4@videotron.ca
