Old 08-11-2016, 10:25 AM
Dean Pichon Dean Pichon is offline
Default Firewall eyeball penetration dimension question
Would anyone know the hardware spacing for these firewall penetrations:
Thanks!
Old 08-11-2016, 11:51 AM
Raymo's Avatar
Raymo Raymo is offline
They come with a small piece of paper that tells you how large to make the center hole and where to put the screw holes. The dimension for the center hole is wrong (too small) and it is best to just use the metal as a pattern, rather than the paper pattern.
That said, I do not recall the dimension in question but I can take a measurement this weekend.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 08-11-2016, 12:01 PM
Thanks! I'm fabricating a part to interface with this penetration, but don't have the part in hand.
Old 08-11-2016, 07:24 PM
rzbill's Avatar
rzbill rzbill is offline
A tip.
These eyeballs do not create a gas tight seal by themselves. They need some goop to seal them up. If you want the goop on the engine side of the firewall, vs the cabin, make sure to point the eyeball face shown in the above image towards the cabin side.
Bill Pendergrass
ME/AE '82
Old 08-11-2016, 08:43 PM
BillL BillL is offline
Thanks!
1.000 inches Square for the 4. 1.625" for the span of the two. 1.079" dia hole.
I made a test piece from aluminum first. Made it perfect, 063 and it became the drill guide.
Bill
RV-7
Lord Kelvin:
Old 08-12-2016, 05:20 AM
Bill,
Thanks so much! This is just what I need.
Regards,
