  #11
Old 08-08-2016, 07:19 AM
Plummit's Avatar
Plummit Plummit is offline
Is the failure the mounting bolts to the engine, or the assembly bolts that hold the starter together? I wish I had heard of this last week before I changed my oil.
-Marc
RV-10
N814RV
2020 Donation Made
Old 08-08-2016, 07:30 AM
RONSIM's Avatar
RONSIM RONSIM is offline
Default Assembly bolts
the ones that hold the drive motor to the gear box on the starter.
RV-10 Co-built, maintained, flown (sold)
RV-8A Maintained and flown (Sold)
RV-6A Bought and Flying (N177RV), upgrades $$$
IO360, 180HP/CS, AFS 5600T, D10A, G650, G430, G327, ADS-B, VIZ385 AP
Very Happy Contributor
Comm, SMEL, CFII, A&P
Based at KCLW (Clearwater, FL)
Old 08-08-2016, 07:45 AM
Low Pass's Avatar
Low Pass Low Pass is offline
I have found various fasteners loose on my Skytech starters over the years. Always addressed with thread locking compound. They have never recurred.
Bryan
Houston
Old 08-08-2016, 08:13 AM
BillL BillL is offline
Default Short M5 bolts?
Do you mean the short M5 bolts - D in this image?
Some background for your solution. Read this : http://www.hexagon.de/rs/engineering%20fundamentals.pdf
Edit:
Likely due to the lubrication of the threads resulting in higher applied tension (see reference above). Excellent data leading to a durable solution - it says, the bolt and threads are strong enough. It might be enough just lube the threads for torquing, maybe a clue for SkyTec engineers. Locking does not hurt though.
Bill
RV-7
Lord Kelvin:
Old 08-08-2016, 09:06 AM
DanH's Avatar
DanH DanH is offline
Bill, The Master of Understatement
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-08-2016, 09:28 AM
Bavafa Bavafa is offline
Does any one has a picture of these bolts? Since Skytech replaced my first starter under warranty, I have not had any issues with mine and have been checking the two long bolts that hold the case together with no looseness. It has been over 500 hours since mine was replaced.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 08-08-2016, 10:35 AM
RONSIM's Avatar
Smile Skytec has a new one on the way
My buddy talked with Skytec and they have shipped a new unit. Good for them. Always great service! But, this will be the second replacement, for the same problem. We will inspect it at the next oil change (and subsequent).
I will take a look at the old one, before we ship it back, and determine if I can put a bushing in the motor flange bolt hole, to take up the extra space. If so, we will do the mod on the new starter, before we install it.
Ron
Old 08-08-2016, 12:52 PM
This is a funny thread, I had a Saturn . . . my daughter had a Saturn, and it developed a large rust hole under threshold plate on the sill under the left side back door. She found it just 2 months past the 8 year rust through warranty, the service manager said - "I'm sorry your warranty has expired . . . . we have never seen that before. "
I went directly to parts (100 ft away), the parts guy said -yeah it happens all the time, we have a special kit for that. Yeah, funny. Ever so happy to sell that car. I wonder that happened to that company
Bill
RV-7
Lord Kelvin:
Old 08-08-2016, 01:06 PM
Low Pass's Avatar
Even with 2, maybe 3 occurrences of finding a loose fastener on my Sky-Tecs in 1839 hours and 16 years, I am *really* glad I wasn't hauling around one of those ~15-20-lb Prestolite starters.
Bryan
Houston
Old 08-09-2016, 08:38 AM
Captain_John's Avatar
My SkyTec NL starter did the same thing. That is why I replaced it with a B and C.
The two cheeseball metric M5 bolts that hold the starter motor to the drive stretch, bend and deform. I was replacing them all the time and finally got rid of it to Mike Bullock to deal with!
Good luck Mikey!!!
CJ
The experiment works!
