  #11
Old 08-07-2016, 10:12 AM
Snowflake's Avatar
Originally Posted by flyingriki View Post
What clever methods of labeling have folks come up with? Maybe a graphic on the side of the fuselage?
I bought the Tosten non-military grips (still lots of buttons, but less overtly military), the installation manual for them had a great graphic showing the top and side view that I meant to take and annotate with switch functions. Then I was going to print a label with the graphic large enough to read (about 2" high) and stick it on the panel somewhere it could be seen from both seats. Both sticks do the same thing, so the diagram would be valid for either seat.
Rob Prior
Old 08-07-2016, 01:18 PM
SMO's Avatar
SMO SMO is offline
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 08-07-2016, 05:26 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
FWIW - I have an Infiniti grip with the following set up for the switches:
The pilot and co-pilot grips are mirror images of each other. Since I have manual flaps I put the fuel pump on the toggle switch. I ran the trim ground from each grip to a small SPDT switch on the panel so I can select which pilot can adjust the trim. On the actual grip I also used the Ptouch clear tape with white lettering labels trimmed down to size. I never thought that after over 400hrs they would still look good. I find my set up very "user friendly" and really like it. YMMV
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 08-08-2016, 10:54 AM
Raymo's Avatar
Raymo Raymo is offline
Not too different from other Infinity grip users. I just finished wiring mine this past weekend. It was time consuming but I know it will be worth the effort - long term.
* Coolie hat - pitch / roll trim wired through Dynon AP panel (no need for relays; adds safety features and auto-trim).
* Top 3 way swtich - flaps wired through relay
* Trigger - PTT
* Black thumb - AP disconnect
* Green thumb button - Radio flip-flop
* Blue pinkie button - not used (could be fuel pump on/off)
Switch on panel disables all co-pilot buttons except PTT.
Required one 15 pin d-sub (male/female) for each stick.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 08-08-2016, 01:04 PM
acroflyrgirl acroflyrgirl is offline
Default Infinity
I have an Infinity. The buttons are great and practically a necessity for formation flying.
Red - PTT
Green - Flip Flop
3 way - Flaps
Coolie hat - Trims
Blue - A/P CWS
I am going to use the black one for smoke.
I probably could get rid of the A/P function if I need another switch on the stick.
RV6 aka; Pop Tart
Old 08-08-2016, 01:18 PM
bret's Avatar
bret bret is offline
My green top button is engine start, I didn't think I would like it there but after using it a few times, I REALLY like it there, I don't think I will be using the big red push to start on the dash, it still lights up red when I push the stick start. After reading the reasoning behind it, it really makes sense on how valuable this would be in a worse case scenario. I have the momentary flap down and switch up for retract, I had a relay conflict between the two sticks so there is a priority switch for pilot and copilot only functions.
