08-02-2016, 05:42 PM
Lycoming vs Continental Titan -IO540
Had a great time as Osh last week, one of my goals was to pick and engine supplier. I am a lot smarter on the topic vs a week ago buts still pretty ignorant overall and would greatly appreciate the input of others.
I really want to run Mogas, I plan on stock 8.5 compression, electronic ignition and will be plumbing the fuel system with a return line to accept electronic fuel injection. A Lycoming thru Van's is a viable alternative but would require modifications along with pulling parts and selling (mags, fuel injection system etc.) as they will not customize.
Continental seems very open for building with electronic ignition and electronic fuel injection (supplied by others)
I would appreciate the comments on others of the pros\cons of using a Lycoming IO540 vs. Contiental Titan IO540 as I understand there are some differences in cylinders and some components are offered in Magnesium for weight reduction (accy cover) and intake manifold\sump.
Steve
Steve
RV8 Flying since 2007 - Now for Sale
RV10 - Flying (Jan 2020)
08-02-2016, 06:04 PM
I'm certainly no expert, but I suggest you start with the easy stuff:
1. Check weight. I think the TCM is heavier, and the -10 is already a nose-heavy airplane.
2. Check dimensions. I think the TCM hangs down lower, relative to the crankshaft flange, than the Lycoming (due to cam below vs cam above crank). This may bring up issues with nose gear strut clearance.
3. The inductions are different. For sure you will be designing your own cowling inlet, filter, etc. design.
4. Probably a different engine mount (?).
None of this is insurmountable, but does require thought and work.
08-02-2016, 06:17 PM
Hey Bob
My understanding from Continental guys is their Titan version is a clone almost the same size same weight same intake, I even asked him about the baffling and they said stock vans should work fine. Maybe a little bit of adjustment around there cylinders which are slightly different shape.
I was quite surprised the continental makes lycoming clone.
Steve
Steve
08-02-2016, 06:29 PM
The Titan O-540 is a clone of the Lycoming O-540. It is a bolt in replacement. None of the factors listed above are at work here...
I've toured the Continental/ECI/Titan factory. I'm not an expert on engine factories, but am a manufacturing guy and an engineer, and it seemed like they had their bases covered.
On the other hand, I've spoken with several prominent shops which build up "kit" engines and rebuild engines for the experimental market. They seem reluctant to use Titan/ECI/Continental parts, but when I ask for specifics as to why, I don't get a lot of information. One interesting question posed to me by one of the well known rebuild shops when I mentioned Titan was something to the effect of "Do they have a counterbalanced 540 crank yet?". That's on my list of questions to ask the next time I talk with the Titan guys and gals.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
08-02-2016, 06:33 PM
Originally Posted by steve murray
Hey Bob
<snip>
Steve
Continental bought out ECI a year or so ago. ECI made PMA'd parts for both Continental and Lycoming engines, plus a line of Lyclones marketed under the Titan brand. The purchase presumably took one competitor off of the table for Continental parts, and gave Continental a foothold in the Lycoming market.
Here's AVweb's take:
http://www.avweb.com/avwebflash/news...-224034-1.html
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
08-02-2016, 08:06 PM
"Do they have a counterbalanced 540 crank yet?". That's on my list of questions to ask the next time I talk with the Titan guys and gals.[/quote]
Kyle, can you comment on the benefits of a counterbalanced 540 crank?
If Continental does not have one on the IO540 is it a choice, patent issue or other? (I am assuming Lycoming has a counterbalance crank?) Sorry if these are basic questions, I am at the beginning of my learning curve...
Steve
Steve
08-02-2016, 09:29 PM
Steve
I am no expert on crankshafts. My understanding (mostly from looking at the TCDS's on O and IO-540's) is that there are several different crankshaft counterweight configurations and they are tailored to different applications/prop's. In my search for a -540, I've used the TCDS for the IO-540 D4A5 as the gold standard, and have looked for an engine or crank that matches the one on that engine or can be modified to match it.
Here's the TCDS on the parallel valve IO-540's:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/ffae5a2bb5506dcc8625747a00650001/$FILE/1E4.pdf
You can go to the end of the document and determine all of the internal differences between the various models.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
08-02-2016, 09:37 PM
It is a clone, other than the differences familiar to any 4-cyl Titan owner.
Both Lycoming and Titan 540 cranks are equipped with pendulum absorbers. They have nothing to do with balance. I'm just sayin'.
Quite a few Titan (or ECI, or Continental San Antonio..please Mr. Management, make up your mind!) parts are intended to be PMA replacements...same as Lycoming, but cheaper. You see some crazy things at Continental these days. Here's an example. They can sell you the cylinder too:
Dan Horton
RV-8 SS
Barrett IO-390
08-03-2016, 05:39 AM
There were a few differences vs Lycoming that the sales guy mentioned would like to get comments on the pros\cons of each
- magnesium accy cover case (available only if "heavy" accy items are not to be used"... I think he was referring to large backup alternators) and magnesim sump --- are there pros\cons to magnesium beyond weight & cost.... someone mentioned to me magnesium has corrosion issues....not sure if this a an old wive's tale.??
- Different porting on the cylinders (not sure if this was intake or exhaust or both?)
- Different cylinder fin geometry on portion of the cylinder closest to the case to promote more cooling
- Different material on cylinder internal walls?
Not sure what is real and what is salesperson selling?? Would appreciate input from those more knowledgable than me.
Steve
Steve
08-03-2016, 05:48 AM
In this context, an OWT. A million VW's can't be wrong
Venturi valve seats. Without a flow bench, nobody knows. For sure, they don't matter much if the seat material doesn't match the port wall, and that can happen.
Less fin area near the cylinder bases, less cooling, PITA to baffle well as compared to non-tapered fins.
Nickel carbide, vs hardened steel.
Dan Horton
RV-8 SS
Barrett IO-390
