08-02-2016, 02:04 PM
Does Experimental need an FSM on IFR GPS
Forgive me if this has been asked and discussed before. I did use the search feature and found nothing.
I recently installed a Garmin GNS 480 and was wondering if I need to get a flight service manual to make it and the plane IFR compliant. I seem to recall needing an FSM in the certified world but was unsure if that applied to experimental cat...
My guess is that the FSM is not required in the experimental cat.., but was looking to find out from others and perhaps get a ref in case I am challenged on it.
Thanks...looking to finally finish my ifr rating soon.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
08-02-2016, 02:35 PM
Super Moderator
Not needed.
That doesn't mean it wouldn't be a good idea.
Vic
 Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
08-02-2016, 03:05 PM
FMS
Ryan send me your email I can send you a copy. I have the GNS480 in the Lancair. Did you have the software upgraded to ver 2.4
Bill
Lancair 320 & 360
RV-4 in the hangar
Dues Paid 2016
08-02-2016, 05:11 PM
FMS - Flight manual Supplement.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
08-03-2016, 07:48 AM
Thanks Walt... was hoping someone would correct that.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
08-03-2016, 07:57 AM
Seeing as how experimentals do not have approved flight manuals...
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
08-03-2016, 10:28 AM
Hi Ed, my POH may be unapproved... but it resides in the side pocket. I even actually read it sometimes !
Reason: spelling
08-04-2016, 08:06 AM
Flight Manual Supplement GNS 480
Ryan did you get the 3 gns480 files I emailed to you..
Bill
Lancair 320 & 360
RV-4 in the hangar
Dues Paid 2016
