Old 08-02-2016, 06:08 AM
jabarr jabarr is offline
Default Relief holes in O-360-A4J
Considering converting a -A4J case for constant speed use. It already has an ECI hollow crankshaft. I understand there are a couple of relief holes in the nose of the case that relief oil pressure from the front bearing area that must be plugged for the conversion. Where are these holes? And can they be plugged without splitting the case? Mahlon???
Old 08-02-2016, 09:21 AM
mahlon_r mahlon_r is offline
They can be plugged but you have to disassemble the engine to do it.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 08-02-2016, 09:25 AM
Thank you sir! Kinda suspected that but wanted to hear from the expert!
