The vast majority of electrical problems are due to bad connections. So check every connection. Do you have a digital copy of an electrical schematic to share with us? If not, there is a free program called
ExpressPCB that makes it easy to draw schematics. It is a two part program, one part for the schematic and one part for making a PCB.
Describe the physical location of the MGL wiring in relation to the other aircraft wiring.
