  #21
Old 08-02-2016, 10:08 AM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
Originally Posted by 1001001 View Post
At what altitude does a normally aspirated IO-540 rated at 260 at sea level begin to make only 230 hp?
Is the diesel turbocharged or normally aspirated--maybe a stupid question but I'm ignorant on diesels? I'm assuming turbo'd which is where it's easy to see, now that you've brought it to my attention, they'd get the performance at altitude to offset the HP reduction. That would be appealing if the cost is not significantly higher than an IO-540. Again I'll reserve judgment until performance figures, reliability figures, installation details, and cost are published.
Of course I'm more concerned about getting off the ground with a fully loaded plane on a hot day than cruise performance at 10K.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 08-02-2016, 10:12 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Originally Posted by Auburntsts View Post
Is the diesel turbocharged ?--
Yep, the thing hanging below the engine.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
About 4000 feet. I'd also be surprised if you can buy this engine for less than $65K.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 08-02-2016, 10:14 AM
Auburntsts's Avatar
Thanks - I'm at work and the pics are blocked.
PP ASEL-IA
WAR EAGLE!
Old 08-02-2016, 10:53 AM
kamikaze kamikaze is offline
Here's a link with some details ...
http://www.continentalmotors.aero/up...cSheet-WEB.pdf
J.F.
Sling 4 empennage kit on order!
Future EAA 245 Member (Hopefully)
Current Piper Warrior PA-28-151 Owner/Pilot
Ottawa, Ontario, Canada
http://www.sling4.ninja
Old 08-02-2016, 11:02 AM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
Maybe you'd get both with the diesel? Density altitude might put the diesel close to or above the hp of the 540 on the ground. One of my local airports (KMGY, elev 952') is showing a DA of 2905' today, and it's not even really hot yet.
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
20K more than a Van'S IO-540 new price.
Looking at 100LL.com, there's on average let's say a 80 cents difference in favour of jet-A, per gallon.
Continental claims 10.94 G/Hr on the CD-230, let's use 11.
For an IO-540, let's say 16.
5 * 80 cents = 4$/Hr difference on fuel costs.
5000 hours to break even, based on these very simple calculations ...
So yeah, only truly useful to those without a good 100LL source.
And if someone ends up producing a viable drop in replacement to 100LL, who knows, it could go worldwide ... and kill Diesel in at least some other parts of the world??
Don't see the point at this time ...
J.F.
Old 08-02-2016, 11:11 AM
gfb gfb is offline
Your math is a little off.
CD-230 = 11gph @ $4.19 = $46.09/hr
IO-540 = 16gph @ $5.00 = $80/hr
difference is $33.91/hr
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 08-02-2016, 11:24 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default certification SNAFUs, and more
Well, the diesels are only allowed to fly so high - I think 13000MSL or so? Seems they can't get restarted if someone pulls the power back to where the compression ignition fire goes out. The engine will run up to 18000MSL or so, but I would expect a small throttle reduction - as would be used in any descent - and the fire will go out - until you get to a lower altitude.
So you have to make powered descents? No thanks - I like to keep Mr Vne happy (except at Reno - he has to take what I give him while we are there).
I'm almost sure this basic engine was used by the Flying Frog race team that had a diesel in an NXT. Once they turned the wick up, it really went. So - the HP limit is NOT 230 hp - I would guess closer to 350 (judging from the speed). The plane was totaled in a crash in France later - engine failure, if memory serves...
Carry on!
Mark
Old 08-02-2016, 12:01 PM
DanH's Avatar
DanH DanH is online now
That nicely defines the fear I detect when I talk diesel EAB with senior folks at Continental. They figure if left to our own devices, we'll install it wrong and treat it badly, and everyone will start saying their diesels are no good.
Dan Horton
RV-8 SS
Barrett IO-390
