Old 07-31-2016, 04:58 PM
scsmith scsmith is offline
Default High-Voltage problem solved! :)
This was discussed in another thread last week. Plane Power alternator, 400 hrs. indicated voltage at cruise conditions was 14.8 to 15.2 V With added load, like lights, the indicated voltage would drop to 14.4 V.
Bob Turner said it was an indication of some line resistance in the field wire.
I checked the terminal connections at the field switch and at the master switch (which must be on to energize field). Both fine.
I pulled the field connector plug off the back of the alternator and pinched the contact sockets closed a bit, as demonstrated by Dan Horton.
Problem solved. Indicated voltage is 14.4 now, regardless of load.
Thanks guys!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 07-31-2016, 05:15 PM
DanH's Avatar
DanH DanH is online now
Steve, squeezing the contacts didn't last with mine. I'd suggest ordering a new plug, just so you have it on hand. Search the threads, because I recall someone finding them for way less money than Plane Power wants for them.
Oh, and pot the back of the plug with some silicone sealant so the terminals can't wiggle. I think fretting contributes to contact wear/resistance.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-31-2016, 05:55 PM
Thanks Dan,
I found that old thread. I was reluctant to pot the connector because it precludes replacing it without splicing on more wire. But if I pot it, maybe I won't need to replace it.
So, I'll use the same liquid rubber you did.
Thanks again.
Steve Smith
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
