Old 07-24-2016, 05:04 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
Default Difference between Slick 4345 and 4372?
Hello. Does anyone know what is the difference between a Slick 4345 and a 4372? Both are impulse coupled magnetos intended for the left side.
Thanks you!
Jerry Esquenazi
RV-8 N84JE
Jerry Esquenazi
RV-8 N84JE
Old 07-24-2016, 05:54 PM
jabarr jabarr is offline
I sent jerry the answer but I'll answer here as well in case others have the same question. The 4345 is a retard breaker mag that requires a slickstart box or equivalent. The 4372 is an impulse mag with a 15 degree lag angle.
Old 07-24-2016, 06:02 PM
RV8Squaz's Avatar
Thank you Jon!!! You the MAN!!!
Jerry
Jerry Esquenazi
RV-8 N84JE
