Old 07-22-2016, 10:27 AM
Bluebeard Bluebeard is offline
Default Fuel filler caps o-rings
My tip tanks came with standard Vans filler caps (big o-rings are brown).
Can anyone tell me the MS numbers for (a) the large and (b)the small o-rings used in these caps?
Old 07-22-2016, 11:04 AM
jcaplins's Avatar
jcaplins jcaplins is offline
from vans:
http://www.vansaircraft.com/cgi-bin/...oduct=fuel-cap
previous thread:
http://www.vansairforce.com/communit...d.php?t=100922
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
Old 07-28-2016, 04:45 AM
Ah, thanks, I was hoping to get the MS numbers as I may be putting various chemicals into tanks that have these filler caps, I need to order o-rings that have the right resistance properties.
Old 07-28-2016, 06:48 AM
aerhed aerhed is offline
Various chemicals? What are you going to do, make chemtrails?
Actual repeat offender.
Old 07-28-2016, 11:27 AM
No I have epoxy resin tanks that I am going to clean out with acetone or failing that with MEK. Neither substance results in happy standard o-rings .....
Old 07-28-2016, 11:48 AM
jabarr jabarr is offline
I know you're looking for MS numbers (which I don't have) but the orings are available from Spruce as well-- p/n 05-02146 (large one) and p/n 05-02147 (small). The Usher numbers end with -012 and -325 which one would assume are the sizes.
