Old 07-20-2016, 10:52 AM
bret's Avatar
bret bret is offline
Default FAA Form 8050-88 question
What did you put on line one for US Identification? And what order did you put your name on line two, last, first, MI ? and this needs to be notarized? Thanks.
Old 07-20-2016, 10:58 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
I just mailed all this a couple days ago. I had reserved a number and that's what goes on the US Identification line, if you've reserved one. On the name, it appears that you can't go wrong with Last Name, First Name, MI That's what is on my Bill of Sale from Vans, my id plate on the plane, and everywhere else. But, I'm sure I screwed it all up somewhere...
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 07-20-2016, 11:09 AM
bret's Avatar
N number, ok, thanks, so on the engine question, is the FAA that concerned with us experimental folks? my engine is now EFII equipped so is there any relevance to my model and serial # now? do I just make one up?
Old 07-20-2016, 11:42 AM
My engine had a data plate, so I furnished all the info thereon. It's a Titan IOX-375.
I think I remember that if it's not a certified engine, you can put what you want on that. As I recall, Mel had a post in re: this in the past.
www.marksrv8.com
