Old 01-04-2007, 07:31 PM
jrouault's Avatar
jrouault jrouault is offline
Default Painting the Firewall
Has anybody attempted to paint the engine side of the firewall? If so, what was the prep and paint procedure?
Jason Rouault
RV-7A Fuselage
http://www.rvbuild.com
Old 01-04-2007, 07:40 PM
walter's Avatar
walter walter is offline
I'm curious why you would want to do that.
If the firewall is kept clean you can see any oil splatter if it's for
that purpose. My experience with painting stainless steel has not been
good.
There is another thread about painting the inside of the bottom cowl.
I painted it white and I'm glad I did. It's easy to see oil leaks and rub
marks.
Just curious.
Walter Tondu
Flying RV-8A - Fastback, IO-390, G3X Touch, 74 HRT
Prior RV-7A Build Log
Old 01-04-2007, 08:15 PM
Captain_John's Avatar
Jason, my point of view is...
Once something is painted, sooner or later it one day will eventually need to be REpainted!
The FW is naturally corrosion resistant and fairly attractive the way it is, not to mention easy to clean.
I am leaving mine the way it is.
However, any one of the painting processes we use for the aluminum typically could be used for stainless. Pick one and look over the data sheets.
CJ
The experiment works!
Old 01-05-2007, 07:06 AM
tomcostanza tomcostanza is offline
FWIW, I saw someone restoring a Navion who had polished the SS firewall. It looked gorgeous.
Tom Costanza
RV-7A Fuse
Old 01-05-2007, 08:02 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Yes, I painted the firewall on my RV-6. FWIW, I polished the stainless on my Rocket. I scuffed the stainless and used a two-part epoxy primer and DuPont single stage polyurethane white paint. After three years it still looked new. Poly paint is good to 450 dF continuous and 500 dF max, well within the temps inside the cowl.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 01-06-2007, 09:10 AM
jrouault's Avatar
Default Thanks
Thanks for the responses. I had seen some firewalls painted and was not sure if there was any benefit. Does not sound like there would be. Good thing, because I hate painting
Jason Rouault
RV-7A
