Old 07-20-2016, 12:33 AM
Cbull's Avatar
Cbull Cbull is offline
Default Window Trim Jig
I've taken so many ideas from this forum but really haven't given back. So here goes:
I think this only relates to RV-10's, why I'm posting here. I don't really know what builders do for the junction where the windows meet the fiberglass on the inside. Here is my solution, sorry if its been done before.
For this example I used 1/4" deep #8507K14 rubber edge trim from McMaster Carr. I basically made a little jig to cut one side off of the edge trim. To cut the trim I generously applied WD-40 to the trim as I pull it through the cutter. 20' of window trim in 2 minutes, perfectly cut.
I used the 3M instant adhesive in the pic below and installed about 3" at a time. The super glue is very expensive, $30 for that little bottle, but wow does it hold. I haven't even put a dent in it with almost all my trim installed.
A picture is worth a thousand words, so here are roughly 7000 words:
Inside of window....
Outside looking in...
Hope this finds someone who needed it
Cory Bull
Click image for larger version
ID:	3908  Click image for larger version
ID:	3909  Click image for larger version
ID:	3910  Click image for larger version
ID:	3911  Click image for larger version
ID:	3913  Click image for larger version
ID:	3914  Click image for larger version
Cory Bull
Lakeway, TX
RV-10 , 70+ Hours and Loving it!!!
Old 07-20-2016, 07:28 AM
Jasonm Jasonm is offline
That looks great! I will be stealing that idea when I start my interior. Thanks for sharing.
Jason McKay
RV-10
Old 07-20-2016, 08:45 AM
Lynnb's Avatar
Lynnb Lynnb is offline
Looks great! So the Scotch Weld is safe around plexiglass? I know superglue will cause issues so when you referenced superglue it made me nervous.
Lynn
RV-10
First Flight 12-17-2020
Old 07-20-2016, 09:19 AM
Cbull's Avatar
Lynn
I glued the trim to the fiberglass and not the plexi. It doesn't take very much to make it hold.
Cory Bull
Lakeway, TX
Old 07-20-2016, 02:36 PM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
Looks FANTASTIC! That is an area that is difficult to get to that "automotive quality" level of finish, and you solution looks great.
The Aerosport headliner shells do a good job for the back seats, but I might steal this idea for the front windows
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 07-20-2016, 02:45 PM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
Default Bookmarked!
...along with a million other links. You guys make the task of building a -10 more difficult by increasing the size of the elephant and the resultant number of bites required to eat him. But that's a good thing, because I'm going for quality and comfort this time around, and the RV bar has been raised in wonderful ways in the last 20 years that I've been a flyer vs. a repeat offender
Thanks for posting this. If Ed K. likes it, I know I want it.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD - 50 hours +
65 years running stock DNA
Old 07-20-2016, 04:49 PM
Cbull's Avatar
Thanks fellas. Ed, it's that "automotive finish" that makes the -10 such a great and tedious project. I have so many hours of fiberglass and finish work that were not part of the plans. Many of the projects got shelved, but the experience and knowledge is priceless. I plan to be a repeat offender, but next time something with 2 seats that requires a parachute while I go loop-de-loop. That one will be more militarized in finish...perhaps a -8 or a -14. Hmmmm, better get this one done first.
Cory
Cory Bull
Lakeway, TX
Old 07-21-2016, 11:06 AM
AviatorJ AviatorJ is offline
That looks fantastic, I fear the quality of my fiberglass work and hope this will hide some of my miss steps a bit.
Justin
RV-10, N10JW
Flying since 2/14/2019
http://operationrv10.blogspot.com/
Old 07-22-2016, 09:38 AM
Bluelabel's Avatar
Bluelabel Bluelabel is offline
That a good idea.... I've caught with that and ended up doing a nice bead of black silicone there... Took a lot of work to get it it right. I might pull it off at some point and try that....
Thank goodness for McMaster Carr, that place is a blessing.
John Walker
RV-10 N265WD
"Miss Whiskey Delta"
BPE IO-540, FULL EFII
KMYF, San Diego, Ca.
KEOS, Neosho, MO
Crew Chief
Grove Aero Super Legacy Reno Racer,
twin turbo, IO-540,
full EFII management system
Race Coordinator STOL Drag coming to Reno, 2019
"so I got that going for me... which is nice."
Old 07-22-2016, 09:57 AM
T.O.Craig T.O.Craig is offline
Default LOVE IT
PONDERING THIS ISSUE FOR A WHILE.. YOU MADE MY DAY..IM GOING TO DO IT!
Craig Rufi
FLYING NOW AFTER 13+ YEARS. NICE FLYING AIRCRAFT!!
RV-10/Empennage/Wings/QB Fuselage/Wiring/Doors done finally, Cowling done. Stein panel complete, and connecting all those wires :-))Thousand Oaks, Ca. Dues paid for 2019
