Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 07-16-2016, 05:40 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post Garmin Mode S Transponder Software Upgrades at Oshkosh 2016
Hello,
We will once again provide free software upgrades for Garmin Mode S transponders used in Experimental aircraft at Oshkosh.
Just bring your GTX 23ES, GTX 330, or GTX 330ES transponder in to us at the Garmin tent at Oshkosh and we will install V8.02 software into your transponder while you wait. It only takes about 2 minutes to accomplish this update.
After being located at the entrance to Hangar D for many years, last year we moved to a new location across from the EAA Welcome Center and the Ford tent. If you look at the Airventure ground map, this is grid K13. From homebuilt camping, just follow Knapp street South to Celebration Way (the main entry street) and turn left
Sorry, but we are not equipped to perform sign-offs for certified aircraft, so please only bring us transponders that are installed in experimental aircraft.
Hope to see you at Oshkosh!
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 07-16-2016, 06:05 PM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Default GNS-480
Any chance you might be able to do firmware upgrades (ads-b gps position source feature) on a GNS-480?
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 07-16-2016, 06:25 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
When did v8.02 come out? I had my gtx330 converted to a 330es in January.
Guy
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 07-16-2016, 07:24 PM
g3xpert's Avatar
Post
Hello Alfio,
We won't be doing software updates on GNS/GTN units at Oshkosh, but this posting shows the software needed for your GNS 480 to be used as an ADS-B position source, and a link to the service document.
Your Garmin dealer should be able to update your unit. Let us know if you have any questions.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 07-16-2016, 07:35 PM
g3xpert's Avatar
Post
Guy
Hello Guy,
Service Bulletin 1578 to install GTX V8.02 was released in early Dec. 2015 for all aircraft. We were installing V8.02 for EAB customers last year at Oshkosh since EAB aircraft owners don't have to wait on STCs. Your GTX 330ES was probably upgraded to V8.02 in January.
You should be able to confirm this from the power-up screen.
Steve
Garmin G3X Support
g3xpert@garmin.com
Last edited by g3xpert : 07-16-2016 at 07:58 PM. Reason: Added note about Osh 2015 updates
Old 07-18-2016, 04:00 PM
penguin penguin is offline
Are you able to work on units brought from overseas?
If I bring my 330 in my suitcase can I get it converted to ES?
Pete
Old 07-18-2016, 04:27 PM
g3xpert's Avatar
Post
Pete
Hello Pete,
We had to chuckle at the thought of you traveling all the way from England to Oshkosh with your transponder.
We don't perform ES upgrades at Oshkosh, but I checked with the service group and learned that Garmin Europe performs these upgrades, so you shouldn't have to send your GTX 330 to the U.S. to have this upgrade installed.
Steve
Garmin G3X Support
g3xpert@garmin.com
