Old 07-13-2016, 04:18 PM
bulldogbuilder bulldogbuilder is offline
Default Addendum to Sport Aviation Gear Jack Article
For those of you that read the July 2016 Sport Aviation/Experimenter, the article was edited from the original and vital info was left out.
The axles for the RV's are NOT hollow. Never have been. The landing gear (as supplied thru Vans) has a hole in the axle mounting pad area. This is what will holding the machine up. The "Z" bracket for the wheel pants is NOT drilled for this hole. You will have to do this yourself. It is conveniently located at the center intersection of the axle mounting bolts. (lower left picture). As I do not know for certain if model changes have been made over the years, the hole in the landing gear is the determining factor of the hole in the "Z" bracket. I drilled mine with the axle bolted on, and slowly opened the hole in the bracket to fit the hole in the gear leg.
The gear WILL grow OUTWARD.
If you have ever tried to remove the wheel pant with a flat tire, one will very quickly notice the lowest two screws are a bugger to remove. Hence the main reason for developing this idea.
Hope this helps someone-somewhere.
Ed
Old 07-13-2016, 04:21 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!
Ed, welcome to VAF
The axle in my 10 is hollow.
What model of RV are you talking about---------I suspect the 8, maybe?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-13-2016, 10:08 PM
Yes, the gear jack is for a RV-8 taildragger. I believe all the other RV's have tubular type gear legs.
The fact that the 10 has a hollow axle would allow the same principle to work.
Simply carry the "adapter" with you.
Where in the world could you possibly go that you could not find a scissor jack in the parking lot.
Ed
Old 07-14-2016, 07:09 AM
BillL BillL is offline
Ed
My 7 has solid legs, but a tube axle welded on the end.
Bill
RV-7
Lord Kelvin:
Old 07-14-2016, 08:21 AM
rv7charlie rv7charlie is offline
Both -4s I've owned have hollow axles; the -7 I'm building has hollow axles.
Old 07-14-2016, 09:31 AM
A bit of clarification: The axel stub may be hollow, but the mounting pad/block is the part that is being discussed. This would be the, roughly rectangular, block with the four mounting holes. My RV-8 is a solid block.
Lifting the airplane from the axle/nut side would be complicated by the wheel pant being in the way. And then the jack being in the way for tire removal.
If I were building today, I would have to think about drilling a hole in the axle mounting block to allow for a longer bolt to be used for lifting. Even a 1/2" would help, but not sure this would even be necessary. Ahhh, the joys of "Experimental".
Ed
Old 07-14-2016, 09:45 AM
Mike S's Avatar
Senior Curmudgeon
The axle stub may be hollow, but the mounting pad/block is the part that is being discussed. This would be the, roughly rectangular, block with the four mounting holes.
Ed
As far as I know, the 8 is the only model to use the flat "Cessna" style gear.
All other models I know of use the round or "Whitman" style gear legs.
Possible exceptions are the 12, and 14---never seen the naked landing gear on them to know for sure.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 07-14-2016, 09:53 AM
Ed
Ed, I read the article and see what you are talking about. The short engagement of that bolt could allow it to slip out. One might consider threading that gear and it won't slip out. No claims of bending though.
Bill
RV-7
Lord Kelvin:
Old 07-14-2016, 06:08 PM
Mike S's Avatar
Senior Curmudgeon
Originally Posted by RV8JD View Post
Wittman (as in Steve)!
(extra words - Hangar, biennial, pedal, etc. ...
OOPS, my bad
Thanks for the correction.
Mike Starkey
VAF 909
Rv-10, N210LM.
