07-13-2016, 02:00 AM
Tite Seal on NPT fitting ... which one?
Hello
There is a lot here about sealing to read. In the section 5 of the Vans Manual, they also stated to use Tite Seal for zhe NPT. But I could not found information about which Tite Seal I should use. ACS sells both,:
- Tite Seal Light Weight
- Tite Seal Medium Weight
Which one should I use, let say for the fittings on a oilcooler, tank drain, fuel sender and so on.
I assume the light weight will be more liquid and may be is more for small fittings and small gaps.
Thanks alot and best regards,
Dominik
07-13-2016, 02:55 AM
Get a tube of Loctite 567 from your local auto shop. It really is the gold standard for this type of work.
Just my opinion, but you will find a lot of people will agree.
DaveH
07-13-2016, 05:46 AM
I use the tite seal light quite often with good results, 567 is also good.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
07-13-2016, 07:27 AM
DaveH
That's what I've read in the forum, and it seemed so universally liked that I use it on my NPT's.
But can you list the reasons why 567 users prefer that over anything else?
Just curious.
Flying RV-8 N880BC
2019 Dues - happily paid.
07-13-2016, 08:08 AM
Just curious.
I think folks just grab onto something that works well and become believers. As long as you use an appropriate thread sealant, you will be just fine.
I have, and use, both Loctite and Permatex. They both work well.
I am sure there are other thread sealants out there that perform well in addition to these brands.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
07-13-2016, 08:19 AM
What about for the nylon npt fittings used with brakes? Use the same stuff?
Scott Black
VAF dues 2020
Instagram @sblack2154
07-13-2016, 08:29 AM
This is what the big boys use.
Hylomar? Aerograde PL32
I used original
Hylomar? Universal Blue
It can be used also for flat matIng surfaces
Remove easy with a rag and acetone
Bill J
07-13-2016, 08:40 AM
Permatex isn't recommended for plastic fittings, not sure about the Locktite.
For these fittings, I use EZ Turn Fuel lube, well, cause that is what I have on hand. I am not sure it does much as the plastic threads are somewhat elastic and seem to make a good seal even when dry, as long as you can clock them correctly and still get them tight.
EZ turn appears to have similar properties to the PL32, and I have used it on pipe threads with good results but it doesn't claim to be a thread sealant like PL32 or the other products.
This is the low pressure side and much more forgiving.
Bucker Jungmann
RV1 - Proud Pilot.
07-13-2016, 10:59 AM
Thanks. You have a Bucker? Sweet! I hear they are the nicest flying airplanes ever.
Scott Black
VAF dues 2020
07-13-2016, 11:12 AM
Certainly the nicest I have flown, but the RV3 is a close second, almost twice as fast on the same fuel burn, and the cockpit is much more civilized
Bucker Jungmann
RV1 - Proud Pilot.
