07-12-2016, 07:17 PM
Engine baffle question
I am building a -7. I have been studying my up coming baffle job and am wondering if anyone has ever tried making the baffles out of something other than aluminum such as carbon steel or stainless in the oil cooler area to prevent cracking. I am kind of thinking out loud hear. I know that most lawn mower engines have steel baffles and they endure a lot of shaking and stress. Any thoughts?
RV 7
07-12-2016, 08:44 PM
experience seems to indicate that the Van's baffle structure is relatively robust if you heed some of the warnings, advice, ideas on this site. The #4 corner holding the oil cooler can be successfully reinforced to last 1000's of hours, based upon many posts I have read. Suggest you search for some of the reinforcement/bracing ideas. If you're considering making your own, I would research this as well. I have read a few posts talking about the work involved with the old baffle kit vs new. And that was still partially pre-fabbed. Your making a LOT of work with only limited benefit.
Larry
07-13-2016, 06:02 AM
Research says this will work to overhaul.
I would agree others have made this work. Do some study and look your self. There are three areas for reinforcement on the parallel valve with the standard vans cooler. Niagara 20002a. 1. The vertical interface at the LR corner - add an angle 2. A structural tie from the top of that angle to the upper forward baffle screw on #4, and 3. some tie back from the center, RS of the cooler back to the head or case. I did mine back to the head with an extended rocker screw.
#1 & #2
Bill
RV-7
Lord Kelvin:
07-13-2016, 08:17 AM
In addition to the three areas Bill shows, another area of concern is the "jog" inboard of the cooler. I followed all precautions, extra angle, brace, etc... and a crack still formed on the inside corner starting at the top of the baffle and moving down towards where the Cleko is shown on Bill's picture.
I ended up reinforcing this corner with a piece of .032 bent to match the profile of the jog and keeping bend radius in mind. That took care of it.
It is very easy to add this reinforcement later. Just watch that corner as we are moving the stress somewhere.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
07-13-2016, 09:22 AM
My engine came with some baffling that is .063 thick. Very sturdy and still lighter than making it from steel.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
07-13-2016, 09:30 AM
I went with Paul Ds thinking of if you can lift the plane by the oil cooler, it may be strong enough, I did like the photo but used .125 3/4 angle and then also to the center case bolts, triangulated the hole thing. Also, the new baffle kit has a different material at the cooler mount area?
07-13-2016, 09:51 AM
The fuselage J-Channel across the back baffle wall I installed has been completely satisfactory on my parallel valve with standard vans cooler. 535 hrs, no cracks so far.
Pictures in the post noted below.
Post in alternate thread
Bill Pendergrass
ME/AE '82
07-13-2016, 10:01 AM
Bret - I know they changed some things about the baffle design, like the formed piece that allows the back of the baffle to be one straight line avoiding the messy jog back. Us early builders had to form this part ourselves, or deal with it with the small pieces of baffle material. Not fun. I am not sure about material or thickness changes, but they certainly where not anodized like Bill's beautiful pieces.
The other common related issues where oil cooler flange cracks. I reinforced the flanges with .063 angle, front and back on both sides. The angle simply acts like a washer and spreads the load across the oil cooler flange. The angle is drilled in assembly and mounted through the same mounting bolts as the cooler. Very easy to do this. Additionally, I used baffle material like a gasket between the oil cooler mounting flange and the baffle. The idea going around at the time was this provided an insulator for heat transfer between the cylinder, baffle, and cooler. Not sure how necessary this was, but I have had no oil cooler flange cracks and my oil temps have always been on the low side.
I too chose the center case bolt as an anchor point for the brace as well. At the time, there was an argument about cylinder head movement and bracing to the cylinder. Not sure anyone lost or won that argument, but the center case bolt was a natural and easy location to brace from, so, there ya go.
Bucker Jungmann
RV1 - Proud Pilot.
09-11-2016, 09:32 PM
Brace material...
Hey Bill,
What kind of material did you make the round brace out of? Where did you get it? Did you heat it to shape the ends?
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
09-11-2016, 10:10 PM
I did this as a new build 500 hrs ago using a hollow piece of alum tube and crudely squashed on the ends. I chose not to connect directly to the engine but higher up on the baffle thru the angle. no signs of distress in anything as of yesterday. no other reinforcements. a machined piece of alum or a steel tube is a better design but mine is lighter.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
