Old 07-11-2016, 06:30 PM
blueflyer's Avatar
blueflyer blueflyer is offline
Default Throttle quadrant without a bellcrank?
I have been trying to figure out a way to use a throttle quadrant (where the cable connects to the quadrant under to rotation point of the friction lock)without the use of bell cranks to reverse the direction of the throw.
Is there a way this can be done for a carburated Lycoming 0-360 with vertical induction?
Old 07-11-2016, 07:10 PM
N941WR's Avatar
N941WR N941WR is offline
I have one of Dayton's throttle quadrants and no bell crank in my O-360 powered -9.
No bell crank required.
I'm not sure I understand your question.
You connect the cable to the TQ so when it comes back, it pulls the cable. On the carb, pulling the lever aft closes the throttle and same for the mixture and prop.
The only mod I had to make was I had to drill a second hole on the Throttle lever.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 07-11-2016, 08:00 PM
blueflyer's Avatar
when you attach the cable to this TQ in the picture, and you move the throttle forward, it pulls the cable backwards, ie closes the throttle. Same for the mixture.
Old 07-11-2016, 08:03 PM
N941WR's Avatar
You are using the wrong TQ. Sell that one and get a DJM quadrant. On the DJM quadrant, the cables attach above the pivot point, not below it.
Here is a picture of mine:
(Click to Enlarge)
there are a couple of systems you don't want to complicate; ignition, fuel, and engine controls. By adding a bell crank to your engine controls, you are complicating things.
I'm not sure which RV you are building but if it is a side-by-side with the throttle in the center, you want the friction lock on the right side. If it is a tandem model with left hand throttle, then the friction lock should be on the right.
Good luck!
Bill R.
SC86 - Easley, SC
Old 07-11-2016, 08:07 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Note the hole location in the DJM unit. It is above the pivot, thus no bellcrank needed.
Can you just rotate the arm on the carb/servo 180*??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-11-2016, 08:09 PM
N941WR's Avatar
It depends on where the stops are on the carb. On my carb, that isn't possible.
Bill R.
SC86 - Easley, SC
Old 07-11-2016, 08:21 PM
spark68 spark68 is offline
(Click to Enlarge)
Bill,
Do you have a picture of how you hold the cable housings near the quadrant?
I'm planning a similar setup and looking for ideas or reference.
Mark Curley
RV-6 (under construction)
dues paid 2020
Old 07-11-2016, 08:23 PM
blueflyer's Avatar
I can't rotate the mixture arm.
Old 07-11-2016, 08:57 PM
N941WR's Avatar
Originally Posted by spark68 View Post
Bill,
There are more pictures on my website, but I think this is the one you are looking for.
(click to enlarge)
What that doesn't show is the safety wire looped around the adel clamp and cable like this.
Others have used a section of AA to make a bracket to secure the cable with. I thought about doing this but wasn't sure where to place the bracket and the adel clamps have worked very well.
Bill R.
SC86 - Easley, SC
