Old 07-11-2016, 08:04 AM
istrumit's Avatar
istrumit istrumit is offline
Default Access to Fuel Sender
Well, it looks like I will need to replace my Floscan 201 sender on my 10 due to intermittent readings. I still have to work on checking some wiring, but I am not hopeful it will be wiring.
I have a tunnel access plate on the pilot side that allows access to the aux pump area, but the sender is a good 12-18 inches forward of that and is essentially inaccessible from the access port.
Is there some way I can get to the sender w/o removing a ton of my interior ?
Scott
Scott Martin
N430WP RV-10 - Purchased
