Old 07-06-2016, 09:05 PM
sblack sblack is offline
Default How to remove foam grip without wrecking it?
I have a ray allen foam grip that came with my project. I am painting all the flight controls and I want to remove the grip to paint but on the 1" dia stick it won't budge. I tried compressed air like it says on their site with no success. Tried putting the stick in the freezer, didn't help at all. Any suggestions gladly accepted!
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 07-07-2016, 12:40 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
I removed mine by letting water run down the side of the stick.
Admittedly it wasn't on for long but a try can't do any harm...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 07-07-2016, 04:56 AM
noelf noelf is offline
Drill a hole in a block of wood that is slightly larger than the stick diameter. Then saw the block in half. Place the block around the bottom of the stick grip and push/pull on the wood to force the grip off. This procedure will allow the stick grip to expand slightly and it can then be slid off the stick.
Noel
RV-6A N6NF
tip-up
flying
Old 07-07-2016, 06:48 AM
Sam Buchanan's Avatar
been here awhile
Can't you just mask the grip and paint the stick with the grip in place?
Sam Buchanan
RV-6
Fokker D.VII replica
Old 07-07-2016, 08:24 AM
flyboy1963's Avatar
Default big fat helpful idea?
wrap vinyl around the stick, seam to front.
from what I recall, about 6" of the stick is visible below the grip and above the cushions...so we're talking minimal real estate here eh?
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 07-07-2016, 08:29 AM
Bavafa Bavafa is offline
Get your air nuzzle from your air tank under it (the nuzzle does not need to go under it) just the air and with the slight pull it comes right out. Try it and you will be amazed.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 07-07-2016, 12:26 PM
I tried it and it didn't budge.
Scott Black
VAF dues 2020
Old 07-07-2016, 12:27 PM
I think my options are to cut it off or do as you suggest. I like your idea better. That foam is some tough stuff!
Scott Black
VAF dues 2020
