Thanks for the re-post, Mike
Yep... it's just as easy as it looks in the video and it really makes a beautiful (welded) end on cables. The RV-12 has four small cables, 2-choke and 2-throttle, that need to be removed from time to time and the welded ends make it a non event. Hopefully this tip will worm its way into the RV-12 plans one day.
Tip #2 - before heating the cable, verify the cable twist direction and twist in the same direction. I just noticed on one of our -12s that the choke cable was a left twist and the throttle was right twist.
R. E. "Ernie" Butcher
Friends of the RV-1/Eagle's Nest Projects
"Mentors build the student...
Students build the airplane." -Glen Salmon
Dedicated to the historical preservation of the RV-1 Aircraft
and organized for the purposes of promoting, supporting,
fostering, and engaging in aviation and aerospace education.
www.RV-1.org
www.EaglesNestProjects.org
