Old 07-05-2016, 01:55 PM
istrumit's Avatar
istrumit istrumit is offline
Default Strong but Removable Glue
I am planning to glue a couple of drilled rivet heads to the static ports to cure a low IAS calibration (see my previous threads on this).
After experimenting with layered duct tape, it is time for the next step, actually attaching drilled rivet heads.
But, in case it doesn't work, i need to be able to easily remove them using some sort of glue solvent that won't damage the paint.
Any recommendations on glue type (and solvent if needed).
Thank you,
Scott
Scott Martin
N430WP RV-10 - Purchased
Old 07-05-2016, 02:07 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Just a touch of JB Weld. If you want to remove them you can pop them off easy enough.
The other option is to just replace the ports with AN470AD6-8 rivets. Drill a 1/16" or smaller hole through the center of the rivet for the port. The rivet shank is a good fit for 1/4" tubing, but use a little JB Weld to make sure it does not fall off. I also added a 1/8" thick, 1" diameter aluminum disc with a 3/16" hole, slide over the rivet shank and glued to the inside of the fuselage skin to provide support.
Carl
Old 07-05-2016, 02:39 PM
Sam Buchanan's Avatar
been here awhile
A thin layer of pro-seal (tank sealant) will do it. The rivet head can be pulled off if necessary.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 07-05-2016, 02:45 PM
DaleB's Avatar
DaleB DaleB is offline
How thick do you need to go? I'd be tempted to use some epoxy (maybe thickened with micro if needed) to form the shape you want, then drill through it. Easy enough to pop off with a knife blade if needed, especially during the first day or so. If you want to glue on a rivet head I'd use epoxy, same deal. Should pop off and if there's any left you could carefully scrape or sand it, no solvent needed.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 07-05-2016, 03:03 PM
Finley Atherton Finley Atherton is offline
If you glue on rivets (AN 470) and the IAS is too high you can try filing a small amount off the top of the rivets in situ to bring the IAS back a bit rather than removing them. Worked for me.
Fin
9A
Old 07-05-2016, 03:21 PM
Another option is canopy glue (sold at hobby shops, brand name RC-56). It's white, dries clear, can be peeled off without solvent and leaves no residue. It's kinda like industrial strength rubber cement.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 07-05-2016, 03:54 PM
DanH's Avatar
DanH DanH is offline
Anybody in your EAA chapter with a lathe? It's easy to turn out a whole static port, compete with barbed hose end. The advantage is that you can go a little bit too tall, then file it down after installation to calibrate precisely.
Dan Horton
RV-8 SS
Barrett IO-390
Old 07-05-2016, 04:57 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
It should pop off easily enough using just a tiny bit of superglue. It did for me.
Having said that, adding a rivet head to my SafeAir ports did increase my indicated speed at the top end, which is what I needed, but it also increased my indicated stall speed at the bottom which I didn't need. YMMV.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 07-05-2016, 06:07 PM
Why not try something easily removed like rubber cement to establish the right shape and size of rivet head, then use superglue or proseal to affix the permanent set?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 07-06-2016, 09:18 AM
Rupester Rupester is offline
There's also peelable window caulk ... You can buy it at Lowe's or Agent Orange.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
