One trick a number of us have used is to drill them out to 0.25, then cut washers out of surgical rubber tubing with an OD of 1/4, and an ID of 1/8. Make the washers as thick as the plexi. Now you have given the plexi a chance to grow and flex.
I've done two canopies that way, with good long term results.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
