Go Back   VAF Forums > Main > Safety
Old 07-03-2016, 04:00 PM
Vac Vac is offline
Default My RV-4 Learns an F-4 Trick
The McDonnell F-4 had a nifty, aural AOA system that allowed you to hear the angle of attack when operating around L/Dmax and slower…it had a “solid tone” that indicated when you were ON SPEED, or flying optimum AOA, let you know when you were slow and really got your attention when you were approaching a stall. ON SPEED was especially helpful during approach and landing as well as maneuvering flight; and the logic allowed the pilot to make fine corrections between slightly slow, ON SPEED and slightly fast when desired. The F-4 didn’t have the greatest handling characteristics, and the system helped the pilot avoid “pulling on the pole” too hard and making bad things happen. I’ve been privileged to have flown lots of airplanes, including fighters and jumbo jets; and I’ve found the F-4 aural AOA system to be the best I’ve used in any airplane.
Recently, I met a couple of smart engineers and fellow RV'ers that have helped to build a prototype system that allows me to program the F-4 AOA tone logic for use in my RV-4 to demonstrate the concept to folks that might not be familiar with it. The “tone generator” is actually a small computer that processes the basic serial output message from my Dynon DY-10A, which includes AOA information from a standard Dynon AOA pitot tube I recently retro-fitted to the airplane. The tone is pumped into the intercom system and the volume is pilot-adjustable (except for the slow tone and stall warning). In the demonstration videos, the camera is receiving raw audio output and it’s much louder than what I’m hearing in the headset; and, to be clear, this is not the Dynon programmable AOA tone.
The AOA tone allows me to hear the “back side of the drag curve” or what you might have learned as the region of reverse command, i.e., where it takes more power to go slower. Optimum AOA lies in this region. At speeds above or AOA’s less than L/Dmax, there is no tone. The way it works, as the airplane slows down (or AOA increases) to L/Dmax, a slow, low frequency beep starts. This reference can be handy, since lots of good things happen performance-wise at L/Dmax. As the airplane slows down more and AOA increases to optimum, the pulse rate of the low-frequency tone increases and changes to a solid tone when you reach “ON SPEED,” or optimum AOA. If you keep pulling and increasing AOA, then the tone transitions to a high frequency and starts to beep again at a slow rate, letting you know that you’re “slow.” And if you insist on stalling, the pulse rate will increase until about 15% or so before the stall a loud, high-frequency quick pulsed tone (that sounds a lot like a stick or pedal shaker) lets you know that the bottom is about to fall out. Here's a picture that illustrates the AOA tone logic: https://drive.google.com/file/d/0B8E...ew?usp=sharing. Here's what that picture sounds like in the cockpit as the airplane slows down from L/Dmax all the way to the edge of the stall: https://youtu.be/S9H6T_tOLe4. The easiest way to conceptualize how this works is that the tone essentially tells you that you are "fast" (low frequency), "on speed" (steady tone), or "slow" (high frequency) when operating at lower airspeeds or higher AOA. The pulse rate allows you to fine tune pitch inputs using this basic logic.
Here’s what an ON SPEED base and final to a low-approach looks like: https://youtu.be/p7PXlOgJUJs. The video starts with the airplane rolling out on downwind and slowing down to begin the base turn. There is about 20 knots or so of over-shooting crosswind at pattern altitude, but only a few knots of right crosswind down near the runway. Prior to starting the base turn, the airplane is configured for landing (Flaps 40) and trimmed for ON SPEED. Throughout the base turn, AOA (tone) is controlled with pitch adjustments. During the turn, you’ll hear some instances of “slightly fast” (a fast-pulsed low frequency tone) and “slightly slow” (a slow-pulsed high frequency tone) as I explore the envelope a bit! Typically, until rolling out on final or approaching the roll-out point, power is at idle for a normal-sized pattern (traffic permitting); but in any case, glide path is controlled with power. Typically, a bit of power is added rolling out on final as the airplane settles “into the groove” for a stabilized approach. ON SPEED is maintained until the flare for a normal landing and you’ll hear a slow tone as I round-out during the low-approach, which is normal. It’s not necessary to look in the cockpit to hear the tone, so the pilot’s eyes are freed up to look at the runway environment and scan for traffic with an occasional cross-check of the airspeed indicator to make sure everything is working as intended. If conditions warrant, then it might be more appropriate to fly a “slightly fast” turn and approach. For example, if conditions are gusty and turbulent or you wish to carry a bit more energy for a wheel landing, etc. Similarly, if stopping distance is critical, establishing a “slightly slow” condition on final might be appropriate.
Currently, I’ve got the system programmed to wake up at 10 knots on takeoff, which lets me hear “what the wing is thinking” as the airplane accelerates; so it’s fairly easy to transition to an ON SPEED takeoff (which approximates maximum performance) for the initial climb segment when it’s necessary or advantageous to do so: https://youtu.be/OtLObb2b_us.
I'll add to this post as we experiment and learn more.
Fly Safe,
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
Last edited by Vac : 07-05-2016 at 09:24 AM. Reason: Updated tone drawing and added link to basic tone demo
Old 07-03-2016, 05:05 PM
F1R F1R is offline
Very nice work on your progressive tone indicator. - You should be able to market that to Dynon users or license it to several of the glass manufacturers.
https://youtu.be/p7PXlOgJUJs Yup it looks like an F4 wallowing in off the end of a carrier deck. If the engine quit, I suspect you might end up a touch short of the runway.
Nice, but now lets see you do an "ON SPEED" approach with the mixture knob pulled out to cut off and a windmilling prop.
Old 07-03-2016, 05:07 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Love it. I wish Dynon had that as a feature on skyview
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 07-03-2016, 06:47 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
I use mine quite a bit since, as you know, there isn't nearly the pre-stall buffet to let you know you're on the gravel/rocks/boulders. It's awesome for getting max turn performance around the top of the egg.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 07-03-2016, 08:50 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Interesting use of available SkyView data. Keep us posted on how it continues to evolve.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2021 Donation made
www.PuertoRicoFlyer.com
Old 07-03-2016, 10:09 PM
vlittle's Avatar
vlittle vlittle is offline
I believe that audible tones are an excellent way to indicate AoA. The F4 audible system may be a tad complex for many, but IMHO it's superior to a visual system.
I've done a visual system and a haptic system (stick shaker) for D1x and SkyView systems using the serial data streams but the audible system has the most potential for those who use AoA to get maximum performance. For stall avoidance, however, I think AoA should add haptic feedback. A stick shaker or rudder shaker works well for that.
None of these methods work well, however, without proper practice or training.
V e r n. ====
RV-9A complete
Harmon Rocket complete
Part of EAA award-winning OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 07-05-2016, 11:22 AM
Vac Vac is offline
Default Maneuvering Flight Application
The aural AOA also assists in maneuvering the airplane, not only in the traffic pattern or after takeoff, but during all phases of flight. The ON SPEED band is actually a key “max performance” point where lots of good stuff happens with turn rate, turn radius and energy management. This stuff is critical in a dog fight, but it’s also important if you are trying not to hit the ground, not stall, and effectively maneuver the airplane within a safe operating envelope. One of the easiest ways to describe how this works is to depict an “ON SPEED” band on a basic VN diagram that all pilots are familiar with. This drawing shows how the ON SPEED band looks for my RV-4 relative to the basic operating envelope for my plane: https://drive.google.com/file/d/0B8E...ew?usp=sharing
There are few concepts depicted in this illustration worth pointing out…First, during 1 G, level, unacellerated flight, AOA and airspeed have a nice, linear and predictable relationship; but if you start to change any of those variables, then the relationship between indicated airspeed and AOA changes. In simplest terms, the AOA at which the airplane stalls doesn’t change, but the indicated airspeed at which the airplane stalls varies by load factor (G). This is why the left side of the envelope curves up from zero airspeed at zero G until it reaches structural limit at maneuvering speed (or “corner velocity” which is a term that simply refers to a corner of the envelope). The ON SPEED band mimics the behavior of the aerodynamic limit: as bank angle and/or load factor increase, so does stall speed and, thus the indicated airspeed associated with ON SPEED or optimum AOA. Here’s a good way to see how this works in real life…this is a video of a steep turn. If you look at the indicated airspeed on round dial, you’ll note it’s quite a bit higher for an ON SPEED condition, then when operating in slow flight or flying a gentle traffic pattern: https://youtu.be/BphHzWHbOjo. Throughout the turn, you can hear the tone vary slightly between ON SPEED, “slightly slow” (high frequency) and “slightly fast” (low frequency) as I make pitch input adjustments. The logic is designed to allow this “fine tuning” for relatively precise pitch/AOA control.
Besides the fact that lots of aerodynamic good stuff happens ON SPEED when you are trying to pull the nose around the sky, the best thing is that you will always encounter ON SPEED when you pull before you stall—sort of! Because the only automatic flight controls in an RV are between the pilot’s ears, it’s possible to pull the stick so quickly that bad things can happen without any sort of warning from the tone or even aerodynamic buffet…if I roll inverted at cruise speed and pull the stick as hard and fast as I can, I’ll likely depart controlled flight before I hear anything but the stall tone after the fact; but that’s only if I didn’t pull the tail off the airplane first. Now this is a worst-case scenario, but it illustrates the concept of how you can beat most warning systems if you try hard enough (or channelize your attention enough to not even be aware of the tone). But, if you maneuver at proper speed and use smooth flight control inputs, then the tone can save your bacon if you try to pull too hard. Here’s a video of me beating the system by performing a rapid pull into an accelerated stall: https://youtu.be/DLtamTAh-Is. In the first stall, you might notice that I don’t even hear stall warning before the nose stops tracking and stalls, just slow tone. The system actually has a chance to catch up, and by the time I induce the secondary stall, you hear stall warning.
Another bad scenario is when you overshoot final a bit, throw in some outside aileron to keep your bank from getting too steep close to the ground, but leave inside rudder applied—i.e., a skidding turn. If you were to continue to pull to the stall, an RV will typically snap roll underneath as soon as critical angle of attack is exceed. But in this case, the slow tone should alert you to need to ease your AOA as you look out of windscreen at an angled final, think about going around and are reminded to center the ball up. Here's a link to an old video of a skidding departure (it was part of a test to look at buffet effects on the horizontal stab in different post-stall conditions): https://drive.google.com/file/d/0B8E...ew?usp=sharing. There was no aural AOA system installed in the plane at this time; and I'm only posting the video to demonstrate how rapidly the skidding departure (snap roll underneath) occurs after the critical angle of attack is exceeded. As we get deeper into testing the aural AOA tone system, I'll update the video showing the view out the front and how the tone behaves during the departure from controlled flight.
Here are a couple examples of ON SPEED maneuvering other than traffic pattern ops and a simple spin entry…Again, note that it’s normal to hear some variation in tone between ON SPEED, slightly slow and slightly fast when maneuvering. You may also note that there is limited stall warning prior to the spin (just slow tone), but I’ve since adjusted the software threshold to fix that; however it does give you some idea how the system works post-stall and during recovery.
Split S: https://youtu.be/kZJpk_hFIbg
Loop: https://youtu.be/0dkVtURCXiw
Incipient Spin: https://youtu.be/nGaJiHO_st8
I'm sure folks a lot smarter than a bunch of curious RV'ers are working on similar systems; so the key will be to develop maximum ergonomic utility across all phases of flight (not just approach and landing) while accommodating the widest range of pilots. And as Vern wisely pointed out in his post, none of this is worth much unless it's combined with good training resources.
I’ll post more as we continue to experiment with the system, and we're very interested in thoughts and feedback from folks in the community; so please post, drop a PM or e-mail.
Fly Safe,
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
Old 07-05-2016, 11:58 AM
Jamie's Avatar
Jamie Jamie is offline
Nice work, Mike. Thanks for sharing. I've always thought that something like this must exist somewhere.
The closest analog that comes to mind is the near-continuous audio feedback from a variometer in a glider which permits far more precise control of the aircraft than only including the VSI in the visual scan.
The only concern I would have is the same concern I would have with pretty much any other piece of equipment to be used during a critical phase of flight -- what are the failure modes? Thinking pessimistically, the worst-case failure for the aural AOA indicator would be that it sticks in the "on speed" mode and provides the pilot with bad situational awareness. I'm curious (from an engineering perspective here) how your team engineered your gizmo so that this cannot happen?
Again, great work! This is cool.
Old 07-05-2016, 12:47 PM
springer springer is offline
Originally Posted by Vac View Post
I'm sure folks a lot smarter than a bunch of curious RV'ers are working on similar systems; so the key will be to develop maximum ergonomic utility across all phases of flight (not just approach and landing) while accommodating the widest range of pilots. Vac
I wouldn't be so sure. I stopped with the F-4 so am not familiar with the follow on F-16's & F-15's AOA warning systems. The F-4 aural system was so user friendly but old technology, I wonder if the knowledge is still out there. After viewing your vids, you have mimicked the F-4 system perfectly. Time to market your system!
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 07-06-2016, 08:25 PM
Vac Vac is offline
Hi Jamie,
That's a great question!
Short answer: A calibration tone is provided to the pilot when the system is turned on to let him know it's working (and adjust volume to desired level); and there is an LED that provides a "heartbeat" signal for the serial data stream; but the tone generator is just a computer processing the AOA signal from the EFIS, so garbage in, garbage out...IAS (and known pitch/power setting) serves as the back-up to confirm proper operation of the AOA.
Long answer:
Even for a system that had indigenous sensors (say adding pressure sensors to the computer in the tone generator, or replacing the pressure input with a voltage signal from a potentiometer driven by a vane or the signal from the nifty new friction-less magnetic sensors driven by a vane, etc.), the best way to determine AOA validity is to compare it to a known airspeed for the condition.
For approach and landing reference, AOA is either primary or secondary. If it's considered reliable enough to be primary, then the pilot normally computes a back-up IAS for approach and cross-checks throughout the approach to confirm that the tone is "valid." Similarly, if the AOA sensor/display is not considered reliable enough to be primary, then the pilot maintains Vref and uses the AOA signal to validate that. Factors that effect the validity of IAS may also affect AOA (e.g., icing conditions). The tertiary "catcher's mitt" is also comparing AOA/IAS to known pitch and power settings. So in this case, part of the "engineered" solution is training the pilot to compare what he sees with what he hears and also what he knows to be correct for pitch and power throughout the approach.
Part of our testing will be to look at lag time and make a determination whether or not the tone is reliable enough to be a primary indication. If you watch some of my approach testing video very closely, you can detect a bit of null (hysteresis) at the cross-over between ON SPEED, slightly slow and/or slightly fast because I'm actually making a fine pitch correction so quickly that I'm beating the system. On a stabilized approach, this effect is negligible and you have to be looking for it to even notice it. On the other hand, at high pitch-change rates, then lag can be sufficient to mitigate some (or all) of the warning provided by a system like this. That's demonstrated in the accelerated stall videos I posted above.
Interestingly, one of the things we considered was replacing with steady tone with a null tone--i.e., if things are going right, no tone present. The only problem with this logic is that there is already no tone at fast speeds/low AOA; and if a "null" tone fails, how do you know without looking at something? On the other hand, it would be practical from a software logic stand point to add a "hey dummy, the AOA data has stopped coming in" warning tone, so we'll take a look at that...thanks for the idea!
The bottom line is that as nifty as a good AOA tone can be, it's still not perfect and the automated RV flight control system (i.e., pilot) still has to process and evaluate the information.
Vac
Mike Vaccaro
RV-4 2112
Niceville, Florida
