01-03-2007, 02:54 PM
Where Can The Oil GO ?? Looking for Miracle/ Voodoo
Last week I posted the following question:
I have recently had the cylinders overhauled on my Lyc IO306a1a. All 4 nitride , honed with new rings. Ground run was held to the Lycoming minimums. 1 run at 800 rpm until the oil reached 140 then let cool completely. The next day I let the oil warm up th 140 then took off ASAP. Max oil temp 222 then dropped to 195 , max cht on the engine monitor was 380 then dropped to 320 or less ,all within the first hour.
I ran the next 4 hours at 75-80% power every 30 min slowly changing power up and down for 10 min. Always 100 degrees ROP.
I am still burning 3/4 quart of mineral oil per hour. When should this stop and drop to the expected 1 quart in 15-20 hrs ?
The response I recieved was beyond expectations. They have educated me in many ways. I now have 7 hours and oil burn is exactly 1 quart per hour. Please help with a few more questions.
I spoke to my cylinder OH shop and they seemed stumped to. I am now burning as much oil as before my overhaul. The engine has no leaks, where can this much oil go ? I have separator on the crankcase vent line and it drains into a bottle so I can tell if any oil is blown out the breather. I have straight stacks and all the pipes are an even color grey inside. Can anyone think of any other way to burn/leak this much oil and it not be obvious?
Thinking from a different direction:
If I wanted my engine to burn more oil what could I do ??
How is it that I followed Lyc. procedure and failed so badly?
Could I have messed it up worse following no procedure at all?
Can an internal oil pump or oiling system problem cause this?
I have all new piston cooling nozzels.
I guess that the most frustrating part is that I am not looking for an improvement from 1 in 10 to 1 in 15. I would be happy with a low 1 in 7.
I can not even meet my low expectations.
I think I will go to about 15 hours then see how I stand. I just can't believe at this point things will improve much. I have built to many motors of all kinds to not be frustrated by this.
Sorry to vent like this, any further suggestions or VOODOO would be appreciated.
LMB
01-03-2007, 03:08 PM
What do your spark plugs look like? Wet?
Dan Checkoway RV-7
01-03-2007, 03:13 PM
High oil consumption
I sent a private message if you'd like to give me a phone call. AJ
Alan (AJ) Judy
Beaver, OK in NO MANS LAND
RV-6 IO360A1B6 C/S Hartz 200HP ?
Also Fly North American NAVIONs
Race car engine builder/Machinist/Fabricator 1982--present.
01-03-2007, 06:16 PM
It is not inconceivable that the overhauler made a mistake (it can happen)...
The wrong rings may have been installed on the pistons (rings for chrome cylinders).
The hone pattern may have been done incorrectly or not honed enough.
Like Dan said...What does the plugs look like? What does the belly of the airplane look like? If you are burning that much oil and sending out the exhaust there will be tell tail signs on the belly.
Scott McDaniels
Hubbard, Oregon
01-03-2007, 07:25 PM
hmmmmm
maybe im late here but does it drop a quart then stop? do you have 6 quarts in it or 8 . some seem to drop to six then hold somewhat steady. if you start withe 6 and fly for 2 hrs is it 2 low? as far as incorrect parts causing this seems somewhat unlikely due to the fact the problem was already here. and the grey exhaust. have you pulled the plugs? this much oil consumption would surely be leaving alot of deposits on the plugs.
William Weesner/ still kicking.
01-03-2007, 10:13 PM
I agree, but it is entirely possible that reworking the cyl. because of excessive oil usage, may have induced a problem that is still causing excessive oil usage.
Call Bart at Aerosport Power (I believe the # is in the VAF yellow pages). I have yet to posed a problem question to him that he didn't have an answer for. His head knowledge of Lycomings amazes me.
As long as you don't take up a bunch of his time I know he would be more than willing to try and give you some help.
Scott McDaniels
Hubbard, Oregon
01-04-2007, 05:53 PM
I will fly 2 more hours on Sat weather permitting and pull the plugs and get compression numbers for a full report.
Stay tuned,
LMB
01-04-2007, 06:20 PM
Stay tuned,
LMB
The last 0360 I owned dropped to about 6 quarts quick after a change and then used maybe a quart every 10 hours. I have no idea where it went, maybe our the breather.
Perhaps you know this, but if not, give it a chance to level off at 6. My engine was so consistent, it was a waste of oil to ad 8 quarts at a change.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
01-04-2007, 06:31 PM
I have run mine starting at 8 down to 4 with no difference.
01-04-2007, 09:10 PM
Stay tuned,
LMB
LMB
A compression check is not a good indicator of ring to cyl break-in.
I have seen good compressions on engines that were still using a lot of oil.
The compression rings can do a good job with the pistons stationary, but because of the poor break-in the oil ring can not do its job which leaves a heavy oil film that the comp. rings float on. The oil gets burned during combustion and then it starts all over again on the next cycle.
Scott McDaniels
Hubbard, Oregon
