Old 01-03-2007, 06:15 AM
N184JG N184JG is offline
Default BEST COMM FOR THE $$$$$
I am building my avionics stack and only need a comm or two no nav. required. So what is the best bang for the buck???
Jim Gallaway VAF#782 2013 PAID 2014 paid
Gundys airport
Owasso,Ok
RV8A N184JG FLYING SOLD
RV7 N1717G FLYING sold
Old 01-03-2007, 06:27 AM
petehowell's Avatar
Default SL-40
It is a bit more expensive, but the SL-40 is hard to beat. It let's you listen to 2 freqs at once and will download freqs from the GPS (if it is a Garmin). I really like mine.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 01-03-2007, 06:28 AM
painless painless is offline
My vote is for the Icom A200.
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 01-03-2007, 06:31 AM
N98HK N98HK is offline
Second the vote for the A-200.
Dave Halasi-Kun
RV-7 N98HK
Old 01-03-2007, 06:55 AM
videobobk's Avatar
videobobk videobobk is offline
Default XCOM 760
I am pleased with my XCOM. Listen to two freqs, NOAA, NAV freqs, all in a 2 1/4" one pound package. Plus it has a great built-in intercom. Cons: pricy and display needs backlight even in daylight.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 01-03-2007, 07:32 AM
13brv3's Avatar
13brv3 13brv3 is offline
Default I love my SL-40
The SL-40 is an awesome radio! I understand the intercom isn't the greatest, but I'm not using it so I can't really say. I never really figured I'd use the ability to send freqs from the Garmin 496, but I was wrong. I use it all the time.
Rusty
RV-8, SN-80587, built, flown, sold.
RV-3B, SN-10751, rotary engine, built, flown, sold
RV-8, SN-82470, built, flown, sold.
RV-3B, SN-11351, purchased, , flown, sold
A&P - 2018
Old 01-03-2007, 07:47 AM
CraigH@KRPH CraigH@KRPH is offline
If low $$$ is the top consideration, the Icom gets my vote as well. Had one in my Citabria, and never expected you could get such a nice radio for so little money.
Craig Helm VAF #585
Graham, TX (KRPH)
RV-4 (sold)
RV-6A (sold)
Old 01-03-2007, 07:49 AM
jcoloccia jcoloccia is offline
If all you want to do is talk, can't beat the ICOM.
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 01-03-2007, 09:01 AM
Jamie's Avatar
Jamie Jamie is offline
My vote is for the SL-40. Two radios for the price of one. Slim...looks good. Absolutely a breeze to wire.
I've used the Icom A-200 in a couple of Diamond DA-20's. They work as well if not better than the GNS430's mounted just above them. Unfotunately the ICOMs seem to have taken a bit of a beating in the rental -20's (i.e. loose or inoperable knobs) where the 430's looked pristine, even though they were all installed in the panels since new. I'm sure if you took care of the A-200 it would be perfectly fine. ICom makes some great stuff. I absolutely love my IC-A24 handheld I received for Christmas. If you're of the persuasion to buy American whenever possible you should note that ICOM is a Japanese company.
I know that a while back some folks (maybe on the matronics lists) were talking about the faceplates of their A-200s melting in the hot sun. It may be something worth checking out.
Also, if you ever think you may be interested in upgrading to a NAV/COM, the SL-40 is the sure bet since it uses the same tray and COM wiring as the SL-30.
Old 01-03-2007, 09:23 AM
prporter prporter is offline
Default X-COM has a NAV receiver?
Hi Bob,
Did you say your XCOM has a nav receiver?
Bob Kelly
