Old 06-27-2016, 06:40 PM
lndwarrior lndwarrior is offline
Default Help with ammeter not working
I have a 40 amp shunt and 40 amp ammeter. This is a new install and the ammeter is not working.
I have checked the polarity and it is correct.
The shunt has four terminals. Two for the main power and two for the ammeter.
I can't remember why (parts on hand?) - but I connected the ammeter wires to the main power terminals. Since it is just a brass bus bar I didn't think this would make any difference in connecting the ammeter wires.
Am I wrong? Is the fact that I didn't connect to the two smaller terminals the reason my ammeter is not working?
Any other ideas?
Tia
Gary
Old 06-27-2016, 06:52 PM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
The smaller terminals are at specific points on the shunt to provide the correct output to your indicator. So, more than likely.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 06-27-2016, 09:50 PM
I'm far from an electrical expert but I can't see how there could be any significant difference between 2 connections on a block of brass a half inch a part.
On the other hand it's possible, I just don't know.
Old 06-27-2016, 10:09 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
If it is the Dynon shunt the difference is essentially zero. The two screws at each end go into the same large block of brass.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 06-27-2016, 10:32 PM
Yea, that's it.
Old 06-27-2016, 10:44 PM
GalinHdz's Avatar
The voltage difference is in millivolts with 1 millivolt per amp as the most common shunt specification. So, "essentially zero" is not zero when you are measuring values that small. I have the exact same shunt for my SkyView and it is a 60A/60mV (1 millivolt per amp) shunt. Before you try anything, check the quality of both lead connections first.
The lead connections are at a very precise location so they can provide a calibrated output. If not, the manufacturer would just have you connect the ammeter leads to the main connectors. If connected wrong you will get erroneous reading which can range from too high (full scale) an amperage to no amps at all. But you do what you think is best.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 06-28-2016, 12:21 AM
az_gila's Avatar
Smile
I disagree... the resistance is based on the cross-section of the material the current flows through.
The drop in the big heavy portion of the end metal is negligible compared to the drop - which is millivolts like you say - of the relatively skinny bar connecting the two end chunks of metal.
Anyway, even if the difference is measureable if wouldn't cause the ammeter to not work, which was the OP problem. If your comments are correct then the ammeter would be reading slightly high, rather than no reading.
If the Skyview is working (most likely) then there are only two wires involved. I would check the crimps and Dsub pins on those two wires.
Gil Alexander
Old 06-28-2016, 06:01 AM
vic syracuse vic syracuse is offline
Super Moderator
It really shouldn't matter on the connection. Is it connected to the EMS box for the Dynon? If so, I have had the box fail with regards to the ammeter and I do believe there is a problem.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 06-28-2016, 07:27 AM
GalinHdz's Avatar
I agree with this. Also, many of these installations, mine included, have the two leads connected through small (1/2A) fuses. If his is connected that way and they blew then he would get no amperage indication as he reported.
Vic
That happened to a friend's DYNON EMS so very possible.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
