Old 06-26-2016, 01:45 PM
lr172 lr172 is offline
Default Continuing Problems with Oil Temps
I have an IO-320 6A. The oil cooler is a Mocal 10 row (same as Setrab and heard several reports of success with 7 row version) mounted on the baffle behind #4. Hoses are new; replaced this spring, -6 size.
I had goods success last fall, with temps remaining in the 190 range even in 90* ambient days. This spring I noticed higher temps reaching max's of 220-225 at 75% power levels. I have replaced the cooler, as I thought it may have become blocked with all the carbon I had in the oil during break-in (due to a glazed cylinder). I have two different verhatherms that I have tried (neither new). The one I flew with today was tested last night. I put it in 190* water and observed a growth of .230" I saw Dan's post and his tested at .248" The minimum is .160 or .180. It would seem that the Vernatherm is working properly.
I don't really know where to go next. I can't see in the vernatherm cavity and I have considered removing the oil filter housing (lycoming style with V/T pointing down) and replacing with screen to rule out issues with the bore that the vernatherm seals. I think that I also have a spring and plug laying around to bypass the vernatherm all together. I have also considered buying a new vernatherm.
Does anyone have suggestions or seen similar problems they could share insight from?
Larry
Old 06-26-2016, 01:56 PM
Toobuilder's Avatar
I'm sure others will jump in here but the first thing that catches my eye is the #6 hose size. Thats pushing it as far as Im concerned. And if you throw in a couple of 90 degree fittings, it makes it worse. Might explore running the #8 hose, keeping it as short as possible, and 45 or 180 degree fittings wherever you can.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 06-26-2016, 02:09 PM
Thanks Michael. There is one straight fitting, two 45's and one 90. All are hose fittings, so a generous radius. I have read quite a few posts on the the subject of -6 lines and it seems the flow is adequate, but could increase pressure. It was my understanding that many engines, including certified, run these lines. I also had good success with this, even during the high heat of break-in. I realize that 8's are better, but it worked for me last fall
Larry
Old 06-26-2016, 02:28 PM
Let's see a few under-cowl pictures:
1) Your baffles and seals.
2) The intake area for your cooler.
3) The exit area for your cooler.
On my -6, I originally undersized the hole in the baffles for the baffle mounted cooler. After 6 months (?) of fighting oil temperatures, I opened the hole up as large as I thought practical, which gave immediate benefit.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 06-26-2016, 03:17 PM
vic syracuse vic syracuse is offline
Super Moderator
Hoese to/from the cooler really should be -8. You would be really surprised if you looked at the flow rates of the oil pump. In a typical Lycoming the complete oil quantity is sometimes cycled in a minute.
Sure there are a lot of other factors, but choking it down to start with is not helping. What works in certified airplanes is not always transferable in our very-tightly-cowled engines.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 06-26-2016, 03:23 PM
I'll take a couple of pics. I forgot to mention that I think my baffles are in decent shape. My CHT's run 340 with #2 at 360* at 75% power. I stay under 400 even in hard climbs. My cut-out for my cooler fully matches the size of the cooler and the bottom of the opening sits just above the fins of #4, so not blocked by the cylinder. Area behind the cooler is wide open and not obstructed.
Larry
Old 06-26-2016, 03:31 PM
I am trying to install the plunger and spring to force everything to the cooler. That should help me troubleshoot the verntatherm / housing and confirm I am cooling as I should with my cooler and hoses.
I have a plunger, but I am not sure I have the right spring. Does anyone have the relaxed length of the 69436 spring used with this plunger? The one that I have sits proud of the top of the threaded opening by a good 1 1/2" It makes me suspect that is is the correct spring.
Larry
Old 06-26-2016, 03:38 PM
Try easy things first, even if unlikely. Pull your temperature probe, provide a ground, and hold it in boiling water. What does it read?
Old 06-26-2016, 03:52 PM
A Good idea. I did that during my initial troubleshooting. It read within a few degrees of a quality thermometer at 200* It also mirrors ambient temps closely on cold startup.
Old 06-26-2016, 06:50 PM
Super Moderator
Default Correction
So I just received an email from a very trusted friend who tells me that they did some testing on the early RV-4's and found they could RAISE the oil temps by using larger lines and that using smaller lines actually made the oil cool better.
I would never have guessed that.
Vic
Vic Syracuse
