  #31
Old 06-23-2016, 08:04 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by Bcone1381 View Post
Mike Busch's webinar is worth watching. You ought to watch it just to become familiar with who he is. A synopsis of recommendations from him backed up with truth and logic is based upon the fact that we rust out engines rather than wear out engines. 1) Use NO Synthetic oil. Revisit this when lead is removed form fuel. 2) Use Single Grade AD oil (50wt) 3) Use Phillips XC when sub freezing engine starts are expected. 4) Use ASL Cam Guard, but no other additives.
Lastly, Mike Busch's C-310 has run his two engines over 200% past TBO. 8 of 12 cylinders are original.
We know lead and synthetic do not make a good match for long drain intervals. My email to Mobil engineers said as much but that's not really the question here since the OP was discussing unleaded Mogas use.
I respect Mike Busch very much but I'm guessing he has little experience with synthetic oils as far as long term sitting corrosion goes. I've used the stuff for something like 33 years, never seen corrosion anywhere inside an engine, even some which were stored for 4 years and a number of these were run on 100LL.
Camshafts and lifters on most engines are are made from very similar material no matter what their mission is. This suggests that the additive package in Mobil 1 might be better than aero oils with regards to corrosion protection. I haven't had a cam go bad since 1983 (not using Mobil 1 in that engine).
The fellow who contacted me many years ago didn't believe all the opinions he read about the matter so decided to just try it himself. He was well aware it could be an expensive lesson so he asked me not to use his name or talk about it back then in case the experiment failed. He didn't want to face the flaming he'd receive.
Like so many things in Experimental aviation, we have many who rarely step outside the tried and true boundaries and issue dire warnings based on little or no fact or experience. This often limits our growth of knowledge and keeps aviation engines way behind other markets.
It's prudent to listen for sure but nothing beats actually doing something to prove it true or false.
"The world is changed by your example, not by your opinion" Paul Coelho
Chinese Proverb: "Those who say it cannot be done should not interrupt the people who are doing it."
The only test case I know of shows it worked fine for at least 800 hours. Just one sample to be sure but it's a start at least.
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
http://sdsefi.com/cpi2.htm
Old 06-27-2016, 07:43 AM
6 Gun 6 Gun is offline
Cool Oil
About 15 yrs ago a couple buddies and my self restored a Stearman with Cont. 220 radial I flew it for a few year before I sold out my part the funny thing was when we ran Aero Shell 15-50 the radial loved it and used hardly any oil.Then when we used W-100 in the engine it would throw a lot down the side of the fuse on start up and used a lot more pre hour.After that I always questioned if straight weight stuck to parts as well as multi weight.
Bob
Old 06-27-2016, 01:19 PM
f1rocket's Avatar
f1rocket f1rocket is offline
My new favorite saying.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
