The pro's that don't use jigs and fixtures to hold bucking bars learn to hold the bars so that they always have finger tips extending beyond the end of the bar face that is forming the shop head of the rivet.
This allows you to feel when the face of the bar is square to the structure (which will also make it square to the rivet) and verify that there is equal clearance around the perimeter which will prevent the bar contacting the structure and causing dents.
It is rarely possible to get a finger on all four sides, but if three sides feel the same, the forth usually will be also. Sometimes you can only get fingers on two opposite edges, but if one of those edges has two fingers you can still gauge the gap in both axis.
BTW, every time someone starts a discussion about annealing rivets it makes me very nervous.
It can be done, but the temp control to do it right is extremely critical. With a very narrow temp range that has to be hit. Get it wrong and you could be building sub standard assemblies with no way to know it.
Scott McDaniels
Hubbard, Oregon
