01-02-2007, 12:20 PM
Com Antenna Doubler Question
I'm mounting my Com antenna on the belly and using a rectangular doubler. The antenna base will ground to the doubler via screws into 4 riveted nutplates, and the doubler will, in turn, be pulled against the inside of the belly skin. I've removed the primer from the doubler and belly surfaces to achieve good grounding, but I worry about corrosion. Is there something I can smear on the surface that will allow good electrical contact, but prevent corrosion?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built  and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
01-02-2007, 04:49 PM
What does the antenna maker say?
DC 4 is an insulator - not really suitable for the job....
Doesn't the comm. antenna come with a rubber or cork gasket for the outer surface?
If this is the case, the only primer you need to remove is on the inner surface under the mounting screw nuts.
A sealer (RTV) is usually recommended around the antenna base edges to stop moisture getting under the gasket.
The best thing is to follow the antenna manufacturer's instructions (surprise...  ...)
A typical set is here....
http://www.comant.com/htmls/guide2.html
If in doubt, follow the instructions....  ... don't do a Tim Allen..
EDIT - UPDATE
Sorry ... the Comant link is for GPS ... this one is for Comm.
http://www.comant.com/htmls/guide1.html
They do talk about direct metal to metal contact... so the DC 4 comment still applies.
Not all antennae are identical... the one I mounted on my Tiger belly had a cork gasket, so removal of external paint would have had no effect. You need to check the specific instructions for your antenna...
SECOND UPDATE
This antenna from EDO (D & M) does use a 0.080 external gasket...
http://www.edocorp.com/documentation/antennas_c70.pdf
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Reason: spelling - update
01-02-2007, 06:29 PM
Gil,
I have instructions just like the ones you posted. They suggest two methods; I'm using the one that grounds through the backing plate.
Steve Zicree
01-02-2007, 09:56 PM
Second try
Gil,
Steve, I think I'm getting it now....
You are only talking about the inner surfaces? ...correct?
If that's the case, just use some RTV at the seams (edges) after the antenna is bolted down to the backing plate. If you stop moisture getting between the plates, you'll be OK.
DC 4 is an insulator, and is not the best for that application where you want good conductivity...
Note that one set of the instructions called for alodine before installation.... this would really help on the long term corrosion prevention, and not upset the conductivity...
.. hope I got your installation correct... gil A
Gil Alexander
01-02-2007, 10:08 PM
We're on the same page now, Gil. I saw the part about alodine and will use it. I like the idea about using rtv around the seam. Thanks.
Steve Zicree
01-02-2007, 11:40 PM
Here's a picture from the Aero Electric Connection. Per Bob Nuckolls, step 1: discard the cork gasket.
Put a bead of RTV around the perimeter of the antenna once installed. The doubler and skin only need to be cleaned around the screw holes in a 1/4 inch radius. In other words, primer is OK except within 1/4 inch of the screw holes. The torque will create an air tight seal around the screws where you stripped to the bare metal.
http://www.aeroelectric.com/Pictures...stallation.gif
My comments are based on those from Bob Nuckolls on the Aero Electric list.
Jekyll
01-03-2007, 07:29 AM
As some have already stated, alodine provides good protection of bare metal surfaces of the skin and doubler while maintaining good electical bonding between the surfaces. An RTV bead around the perimeter of the antenna base should keep out moisture, but don't apply RTV between the antenna or doubler and the skin - it is an insulator.
An alodine "pen", such as the Touch-N-Prep 1132 sold at Aircraft Spruce, Stein Air and elsewhere, while somewhat expensive works great for this without the need for rinsing after application. If you use Alodine 1201 be sure to rinse the surfaces after application.
I am using doubler plates riveted to the skin, the Touch-N-Prep alodine pen applied to bare aluminum between the doubler and the skin - and between the skin and the antenna base, and RTV sealant (only around the perimeter of the antenna base) for all external antennas.
Hope this helps.
Paul Winkels
RV7 Standard Build - First flight 4/16/2016 - Now Flying!
01-16-2011, 02:43 PM
Jekyll
Just to update this thread for future visitors, the above link has now changed to:
http://www.aeroelectric.com/Pictures/Antenna/Comm_Antenna_Installation.gif
Buck Wyndham
Northern Illinois
RV-8 N18XL
01-16-2011, 02:57 PM
I've heard of at tool called a burnishing brush, or at least that's what I think it's called that will make a nice primer free area around a bolt hole and is the perfect tool for this situation.
However, I have been looking a few times and not found where to purchase this tool. Anyone know where to get one?
TIA,
-Jim
